How to Maximize the Height in a Newton's Cradle with Unequal Masses?
  • Thread starter Thread starter Dinheiro
    Height
To maximize the height H in a Newton's Cradle with unequal masses, the relationship H = 16h(M²n²)/((M+n)²(m+n)²) is established. The goal is to find the optimal mass n that maximizes H, which requires using calculus to derive H with respect to n. The derivative leads to a cubic equation, indicating multiple roots, one of which maximizes H. The optimal solution is found to be n = √(Mm), which simplifies the problem significantly. Understanding this relationship allows for effective manipulation of the masses to achieve the greatest height for the ball of mass m.
Dinheiro
An executive toy consists of three suspended steel balls of masses M, n and m arranged in order with their centres in a horizontal line. The ball of mass M is drawn aside in their common plane until its centre has been raised by h and is then released. if M ≠ m and all collisions are elastic, how must n be chosen so that the ball of mass m rises to the gratest possible height? What is that height? (Neglect multiple collisions)
velocity after a perfectly elastic collision
v2' = (m2 - m1)v2/(m1+m2) + 2m1v1/(m1+m2)
After releasing M, its vellocity immediately before the first collision is
V = \sqrt{2gh}
Then, M collides with n, and n's velocity immediately after collision is
v = \frac{2M}{M+n}\sqrt{2gh}
Analogously, m's velocity immediately after n colides
u = \frac{2n}{n+m}\frac{2M}{M+n}\sqrt{2gh}
m shall rises H
mu^{2}/2 = mgH
H = 16h\frac{M^{2}n^{2}}{(M+n)^{2}(m+n)^{2}}
How am I supposed to maximize H from it? What should be done to solve it?
Looks good so far. You have found H as a function of n. Are you familiar with using calculus to find the maximum of a function?
But if you derivate with respect to n, you get
2n³ + (M+m-1)n² - (M+m)n - Mm = 0
probably, three roots, one of them might get H to max. The problem is to find these roots.
By the way, this problem is from a test which you should take 8 minutes each question: there must be a better way to solve it.
I've found a solution
What sorcery did it do to get n = √(Mm)??
Note that the equation H = 16h\frac{M^{2}n^{2}}{(M+n)^{2}(m+n)^{2}} can be written as $$H = 16hM^2\left(\frac{n}{(M+n)(m+n)}\right)^2$$
H will be maximum when the expression ##\frac{n}{(M+n)(m+n)}## is a maximum. So, you just need to maximize the function $$f(n) = \frac{n}{(M+n)(m+n)}$$
Oh, thanks, TSny, I didn't see the reply. I got it
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
