MHB How to Maximize the Volume of a Cylinder with a Given Perimeter?
To maximize the volume of a cylinder formed from a rectangle with a perimeter of 400 cm, the relationship between the radius (r) and height (h) is established as h = 200 - r. The volume is expressed as V = πr^2(200 - r), which simplifies to V = π(200r^2 - r^3). Differentiating this function leads to V' = π(400r - 3r^2), setting the stage for finding critical points to maximize volume. Ultimately, the optimal dimensions are determined to be l = (2S)/3 and h = S/3, ensuring maximum volume for the cylinder.
Noah1
it is given that the perimeter of the rectangle is (80 + 120 + 80 + 120) = 400 cm From this you need to make a cylinder with maximin volume:
400 = 2r + 2h
2h = 400 - 2r
h = 200 - r .
We wish to MAXIMIZE the total VOLUME of the resulting CYLINDER
V = πr^2 h
However, before we differentiate the right-hand side, we will write it as a function of r only. Substitute for h getting
V = πr^2 h
V = πr^2 (200-r)
V = π(200r^2-r^3 )
Now differentiate this equation, getting
V’ = π(200r^2-r^3 )
V’ = π(400r-3r^2 )
- - - Updated - - -
400 = 2r + 2h
2h = 400 - 2r
h = 200 - r .
V = πr^2 h
V = πr^2 h
V = πr^2 (200-r)
V = π(200r^2-r^3 )
V’ = π(200r^2-r^3 )
V’ = π(400r-3r^2 )
At this point I don't know where to go from here to solve for r
Mathematics news on Phys.org
If the dimensions of the rectangle are already given, then we only have 2 choices:
$$V_1=\pi\left(\frac{80}{2\pi}\right)^2120$$
$$V_2=\pi\left(\frac{120}{2\pi}\right)^280$$
Noah said:
It is given that the perimeter of the rectangle is 400 cm.
I interpret this problem as follows:
There is a sheet of paper with a perimeter of 400 cm.
We will "roll" the sheet into a cylinder.
Find the dimensions of the paper which produces the cylinder of maximum volume.
This version requires a bit more work . . .
If we are free to choose the dimensions of the rectangle, so long as the perimeter is a certain value, then consider the diagram:
http://www.ekshiksha.org.in/Image_Surface_Areas_and_Volumes_IX/8.png
Let $S$ be the semi-perimeter (a constant), so that we have:
$$l+h=S$$
The volume of the resulting cylinder is:
$$V=\pi\left(\frac{l}{2\pi}\right)^2h=\frac{1}{4\pi}l^2h$$
At this point we may choose which of the variables we wish to replace, and since $l$ is being squared, for simplicity let's replace $h$:
$$V=\frac{1}{4\pi}l^2(S-l)=\frac{1}{4\pi}\left(Sl^2-l^3\right)$$
Hence, we now have the volume as a function of one variable $l$:
$$V(l)=\frac{1}{4\pi}\left(Sl^2-l^3\right)$$
We may ignore the constant $$\frac{1}{4\pi}$$ and simply optimise:
$$f(l)=Sl^2-l^3$$
So, taking the first derivative, and equating to zero, we obtain:
$$f'(l)=2Sl-3l^2=l\left(2S-3l\right)=0$$
From this, we obtain the two critical values:
$$l=0,\,\frac{2S}{3}$$
Now, if we utilize the second derivative test, on computing $f''$, we obtain:
$$f''(l)=2S-6l$$
And we find:
$$f''(0)=2S>0$$ This critical value is at a relative minimum.
$$f''\left(\frac{2S}{3}\right)=-2S<0$$ This critical value is at a relative maximum.
So, in order to maximize the volume of the cylinder, we require:
$$l=\frac{2S}{3}$$
$$h=\frac{S}{3}$$
Does that make sense?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
