How to measure inverter efficiency
To measure inverter efficiency, connect a 12V battery to a 150W inverter and use an amp meter to calculate wattage by multiplying volts and amps. The wattage of the computer can be measured using a mains socket, acknowledging that modified sine wave inverters may affect readings. Current findings show the computer consumes 52 watts at idle, while the inverter draws 66 to 72 watts, indicating an efficiency of only 30-40%. The discussion raises concerns about inverter sizing, suggesting that a 150W inverter may not be optimal if peak efficiency occurs at a specific load, and highlights the need for a more reliable method to assess efficiency. Overall, the user seeks advice on achieving better efficiency without the expense of repeatedly purchasing inverters.
latter
set up
12v bat. to 150w inverter to a tower pc.
so i put a amp meter between 12v bat and inverter .times the volts by amps get wattage?
then get the wattage of computer using a mains socket(because the inverter produces modified sinewave and my wattage meter may not work correctly with modified sine wave)?
when i have both wattages DC and AC i can work out efficiency of inverter.is this correct.?
so far my computer plus lcd just in idle , desktop is on but i am doing nothing is 52 watts
the wattage between 12v bat and inverter is 66 watts on 1 inverter and 72watts on enougher inverter i have .
i rough idea on this is 30% and 40% efficiency .i find this not good if i am right.
does any know how to get the most efficent setup.
my computer with a wattage meter on. Goes when in use for games from 52watts up to 8o 90 100 watts it is hArd to tell because of the speed of change.i have been told this could be higher but my cheap meter will average out the high watts readings.
should i have a 150watt inverter or 120 watt one.?
inverters always say 90% peak efficiency but don't say what load this peak efficency occurs at.i have been told on a 150 watt inverter you take 15watts off that's the 10% loss
the leaves 135watts so the peak efficiency would be at 134 watts.with a curve going down from there is this correct?
any answers would be helpful
thanks
Can you use a more predictable load like a 100W light bulb? Measure the current drawn and the voltage at the output and back calculate.
yes i could but that wouldn't solve it. but now i think about it are you right because i know bulb is a 100w wow never thought of that idea.
but this would bring me back still to the other problems is my method correct and if i find out as it seems i have 30 to 40% inefficiency what is going on here.I can not afford to keep buying inverters at £30 just to try out its efficiency.
say i am running on average between 50 and 100 watts what size inverter should i look at for efficiency.of course i can get a bigger one but what's the draw back.?
the reason i ask is my method correct is i seem to get high inefficiency results 30, 40 % inefficent.
that is inconsistent with genneral claims of 10, 15% inefficiency for modern inverters
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
