MHB How to modify Adaline Stochastic gradient descent
To modify Python programming for achieving results similar to the referenced image of Adaline Stochastic Gradient Descent, users should focus on implementing the algorithm correctly in their code. Key considerations include ensuring the proper setup of the Anaconda environment with Python 3.7 and utilizing libraries such as NumPy and Matplotlib for calculations and visualizations. Additionally, users should verify that they have the correct data input and parameters for the Adaline model to replicate the desired output. It's also important to remember to attach any relevant files when seeking assistance.
vokoyo
Dear
May I know how to modify my own Python programming so that I will get the
same picture as refer to the attached file - Adaline Stochastic gradient descent
(I am using the Anaconda Python 3.7)
Prayerfully
Tron
Technology news on Phys.org
I've edited your post to remove your email address. It's generally not a good idea to publicly post such information.
Also, you mention an attached file, but there is no attachment. :)
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
