How to open a JSON file in Godot that contains 2 arrays?
  • Thread starter Thread starter Darkmisc
    godot
The discussion revolves around saving and loading two arrays in a JSON file using code. The user successfully saves the arrays into a JSON format, which appears correctly when viewed in Notepad. However, when attempting to load the arrays back, the code returns a null value for the parse result. The issue is identified as a mistake in the loading function, where the user incorrectly references "arrayA" instead of "arrayB" when assigning values to Global.arrayD. Ultimately, the user resolves the problem by deciding to save the arrays into a dictionary instead of using JSON, indicating a shift in approach for data storage.
Darkmisc
TL;DR Summary
I've saved two arrays in a JSON file, but can't seem to open them again.
Hi everyone
I've saved two arrays into a JSON file.
This was the code I used:
[CODE lang="python" title="save"]func save():
var file = FileAccess.open("user://savedarrays.json", FileAccess.WRITE)
var file_path = "user://saved_arrays.json"
var data = {
"arrayA": Global.arrayA,
"arrayB": Global.arrayB
var json_string: String = JSON.stringify(data)
file.store_string(json_string)
file.close()
print("Arrays saved successfully.")
[/CODE]
When I open the file in notepad, this is what I get:
{"arrayA":["France","Spain","UK","Russia"],"arrayB":["Paris","Madrid","London","Moscow"]}
I'm using the following code to load the arrays:
[CODE lang="python" title="load"]func loadArraysFromFile():
var file = "user://savedarrays.json"
var file_text = FileAccess.get_file_as_string(file)
var parse_result = JSON.parse_string(file_text)
print(parse_result)
if parse_result.error == OK:
var parsed_data: Dictionary = parse_result.result as Dictionary
if parsed_data.has("arrayA"):
Global.arrayC = parsed_data["arrayA"]
print(Global.arrayC)
if parsed_data.has("arrayB"):
Global.arrayD = parsed_data["arrayA"]
print(Global.arrayD)[/CODE]
It prints out <null> as the parse_result.
Does anyone know what I've done wrong with the load code?
I used JSON because I read somewhere that that's what I need if I want to save two arrays under the one filename.
Elsewhere, I've used the following code to save one variable to a file:
[CODE lang="python" title="save one var"] var file = FileAccess.open(save_path, FileAccess.WRITE)
file.store_var(Global.thing)[/CODE]Thanks
Technology news on Phys.org
Nvm. I saved the two arrays into a dictonary and saved the dictionary without using JSON.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
37K
