How to Perform Classical Mechanic Transformations?
To perform classical mechanic transformations, begin with a simple case, such as x1 = f1(q1, q2) and x2 = f2(q1, q2). Working through each term in the resulting Lagrangian will clarify the transformation process. Starting with a straightforward yet non-trivial example helps in recognizing patterns. Gradually increasing complexity will reinforce understanding of the general formula. This step-by-step approach is essential for mastering classical mechanics transformations.
Mateusz
Hello everyone, I have a little problem with some transformation.
I wonder how i can get that result. Can somebody explain it step by step?
The " ' " means derivative. Thank you for your time ;)
Try starting with a really simple case, like if you have just ## x_1 = f_1(q_1,q_2)## and ## x_2 =f_2(q_1,q_2)##. You can work out each term in the resulting Lagrangian in this case and that may help you see how it works in general.
As Geofleur said start with the simplest but non trivial case, then step it up a little bit, you'll see the pattern right away and convince yourself of the general formula.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
