How to plot stress - strain and work out the Young's modulus
In summary: With the help of a software program (provided the units are known), one can find the elastic limit.(a) Approximate value of the elastic limitFor this problem, it is difficult to find an elastic limit because the data has a systematic error. A graph of the strain vs stress would be a better way to find an elastic limit.(b) Young's Modulus for the materialThe Young's modulus for the material is estimated to be 8.6 GPa.
Roshane
I have the following table
Load 25 50 75 100 125 150 160 170
Extension 0.38 0.75 1.15 1.53 2.8 8.6 15 28
and I need to:
1. Plot the stress – strain or (load-extension) graph and determine
(b) Young’s Modulus for the material
c) Compare this value with the reference books and state what material it may be.
(d) The 0.5 per cent proof stress
· When the graph is plotted and I attempt to work it out with software, it shows that the data has a systematic error (It doesn’t intercept y at the origin).
This is again shown when a graph of the natural log of strain vs stress is plotted. It should result in a straight line going through the origin, but it doesn’t.
Many fitting programs have an option to set the vertical intercept to zero.
Also, knowing the units would be helpful in advising the solution.
What would an elastic system become if you stretched it too far? How does that relate to part (a) of this question?
You are expecting a nice F = - k x kind of Hooke's law behaviour. But, if a system is behaving elastically, then you stretch it too far, how will the stress-strain curve behave? And does your data look like you would expect it to look if this is the case?
The first four points fall on almost a perfect straight line through the origin.
Chet
That's a good point. For the first four points, the material shows elastic behavior and only deviates significantly from a line through the origin for loads above 100.
This suggest an approach to finding an elastic limit would be to graph the points. Then try fitting subsets of the points to a line. When there is a significant deviation from a line or the line does not go through the origin, you must be fitting to points where the load is above the elastic limit.
Related to How to plot stress - strain and work out the Young's modulus
What is stress and strain?
Stress is the force per unit area that a material experiences when subject to an external load. Strain is the measure of deformation that occurs in response to stress.
How is stress - strain plot created?
A stress - strain plot is created by plotting the stress on the y-axis and the strain on the x-axis. The data points are obtained by subjecting the material to different levels of stress and measuring the corresponding strain.
How do you calculate Young's modulus from a stress - strain plot?
You can calculate Young's modulus by taking the slope of the linear portion of the stress - strain plot. This slope is equal to the ratio of stress to strain and is represented by the letter E.
What factors affect the Young's modulus of a material?
The Young's modulus of a material is affected by factors such as temperature, microstructure, and composition. Materials with higher stiffness and stronger bonds between atoms tend to have a higher Young's modulus.
Why is Young's modulus important in material science?
Young's modulus is an important property in material science because it allows us to understand how a material will behave under different levels of stress. It also helps in determining the suitability of a material for specific applications.
9K
12K
