How to Prove Vector Identity k = (a+b)(c+d)?
  • Thread starter Thread starter colerelm1
    Proof
The discussion focuses on proving the vector identity k = (a+b)(c+d) = (a x c) + (a x d) + (b x c) + (b x d). Participants clarify the distinction between vector expansion and the dot product, emphasizing that the original expression involves vector cross products rather than dot products. One user expresses confusion about how to expand the brackets correctly, while another provides a resource for understanding bracket expansion. The conversation highlights the importance of notation in vector operations, specifically differentiating between round and square brackets. Overall, the participants aim to clarify the correct approach to proving the vector identity.
colerelm1
The following are all vectors:
a, b, c, d
k = (a+b) (c+d)
prove: k = (a x c) + (a x d) + (b x c) + (b x d)
I have tried to start it by doing:
|a| = a = sqrt(a_x^2 + a_y^2)
is that a correct start at it? I really am pretty lost...
As per my other post, do you understand how to expand the brackets to get between the two solutions for k?
Jared
I guess I don't...Could you please explain?
Have a read through this:
http://richardbowles.tripod.com/maths/algebra/brackets.htm
It will show you how to expand the brackets.
Oh, yeah I know how to do that but what if what I meant by "k = (a+b) (c+d)" was actually the dot product of k = (a+b) (c+d) instead of just k = (a+b) x (c+d)? Does that make a difference?
k = (a+b)(c+d) = (a+b)x(c+d) = (a x c)+(a x d)+(b x c)+(b x d)
What you have there is expanding the brackets, this is not the dot product.
The dot product of [a,b][c,d] = ac + bd.
The question shows bracket expansion not dot product. So yes, there is a difference, particularly in notation (dot product = square brackets with commas seperating vectors, expansion = round brackets with standard mathematical operators).
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
