How to Resolve Control Relay Grounding Conflicts in Heliostat Refurbishment?
The discussion revolves around resolving grounding conflicts in a Heliostat refurbishment project involving three-phase motor control. The user is facing issues with control relays not functioning when both forward and reverse inputs share a common ground. Attempts to isolate the grounds using diodes were unsuccessful, but the user found success by using CRYDOM solid-state relays to separate the grounds. There is also a mention of a potential error in the wiring diagram regarding LED biasing, which could affect the control circuit. Overall, the solution with CRYDOMs offers a viable way to manage the grounding issue effectively.
mrgilpin
I'm trying to refurbish a Heliostat and utilize a computer to control the three phase motors that came with the device. However, I'm having an issue with my control circiut for the three phase relays I've purchased.
I'm using two Struthers-Dunn 645RT series SS motor reversing relays which can be found here
http://www.struthers-dunn.com/images/645RT%20Flyer.pdf
The wiring diagram on the 2nd page shows both the forward and reverse control inputs.
I can get both of these to trigger independently utilizing my digital IO board attached to my computer. However, if both of these inputs are connected simultaneously the relays do not work.
My digital IO board only has a single ground, and if both the forward and reverse control inputs share a common ground, the relay will no longer trigger.
The only way to get one of the control inputs to work is to physically disconnect the ground of the opposite input.
I've tried to install diodes on the ground lines to prevent current leakage up into the opposite control but this also didn't work.
Is there a way to electronically isolate the grounds on these control inputs?
I purchased these solid state relays for the switching speed, however, Struthers-Dunn says that these relays are difficult to control unless mechanical relays are used for the control inputs.
An odd note about the diagram on page 2 of the referenced document: It appears the LED input on the right-hand side (Reverse) is biased incorrectly by the battery, while the LED on the left (Forward) appears to be biased correctly. Is it possible the diagram is wrong, and the center terminal is actually a common cathode?
In any case, you might consider using 4 outputs from a pair of 4053's to control your LED inputs:
http://www.onsemi.com/pub_link/Collateral/MC74HC4051A-D.PDF
There are different models with different voltage ratings, but this one should work for you. The 405X series of bilateral switches are really very handy.
Fish
Fish
Thanks for the help!
I didn't notice that error in the diagram, maybe that has something to do with it. I think one of the issues might be that I'm using a older model of this relay that was shipped to me by Newark. My relays do not have indicator LEDs, however, I assume that they are using similar circuitry.
Putting a voltage across the two control inputs individualy as indicated in the diagram DOES work though.
Whats strange is it only functions if the two grounds are not interconnected. I can pull the positive input from the opposite control (breaking the circuit?) and the system still does not function. It's only when the ground are physically separated that the system works.
I'll have to give the 405x series chips a try, however, I'm hoping to get this working by tomorrow afternoon so I don't have time to source the parts.
I have a whole box of CRYDOM DC60S3 SSRs laying around. I'll try to use these to separate the grounds for the system...
UPDATE! Using the CRYDOMs to switch the grounds works. If the 405x chips operate similarly I'll be able to solder up a interface box between the computer and the relays. That'll look much better than the breadboard monstrosity currently sitting on my desk
mrgilpin,
I do not think those are indicator LEDs, I would assume they are opto-isolators, most likely OPTO-TRIACs. Great news on the CRYDOMs working! 4053's are a bunch cheaper and smaller, but if the CRYDOM's work, stick with them!
Fish
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
