(How to) Sending Packets Between Different VLANs
  • Thread starter Thread starter WWGD
Understanding packet transmission between VLANs involves several key concepts. Packets are sent within VLANs using switches, which maintain a MAC address table to direct traffic. When the destination IP address is unknown, the switch broadcasts the packet. For inter-VLAN communication, three primary methods are identified: trunking, which uses a physical link to encapsulate VLAN information; layer-3 switches that facilitate direct connections between VLANs; and traditional routers that can manage VLAN traffic through a single interface. The process is generally straightforward, as routers and managed switches allow for the configuration of VLANs and the rules for packet routing between them. For practical implementation, consulting the manual of a compatible router is recommended.
WWGD
Hi all,
Please critique my attempt to understand the n
I'm trying to understadand the process of sending packets between different VLAns
My understanding is that packets are sent within Vlans by using switches. Packet is sent to switch , which has a
table listing pairings of MAC addresses with their assigned IPaddresses. If the IP address of the recipient is not known,
the switch will issue a broadcast.
But, how are these packets sent between VLAns?
From my reading, I gather the main options are:
1) Trunking . This consists of a physical link between the VLAns.
VLAn 1 will then encapsulate additional information in the packets, which will be stripped away by the trunk,
and relayed to VLAn 2
2) By using some special layer-3( Re OSI model) switch that is able to
connect different VLAns .
3) Using regular old routers, with a single interface?
Is this accurate?
Maybe @Svein would know?
Computer science news on Phys.org
Your quesition seems to span both the physical and functional aspects. This tutorial seems pretty popular. It might be a good match for your questions.
I'm puzzled by the question - are you trying to do this? Your router/managed switch let's you - or should let you - define VLANS and the rules for passing packets between them.
I'm just curious.
Probably best then is to download a manual for a router that supports it. It's preety straightforward - VLANs get routed more or less like other packets.
Well, the date has now passed, and Windows 10 is no longer supported. Hopefully, the readers of this forum have done one of the many ways this issue can be handled. If not, do a YouTube search and a smorgasbord of solutions will be returned. What I want to mention is that I chose to use a debloated Windows from a debloater. There are many available options, e.g., Chris Titus Utilities (I used a product called Velotic, which also features AI to prevent your computer from overheating etc...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
