How to solve certain kind of integral
  • MHB
  • Thread starter ariberth
  • Tags
    Integral
In summary, the conversation discusses methods for solving integrals of the form $$\int_a^b \int_c^{f(x)} g(r)dr dx$$ and concludes that the correct solution is $$\int_a^b G(f(x)) \, dx - G(c) \cdot (a-b).$$
ariberth
Hello everybody!
Are there methods to solve integrals of the following form?
$$\int_a^b \int _0 ^{f(x)} g(r) dr dx$$
ariberth
Ah ok i think i found it allready :)
$$\int_a^b \int_c^{f(x)} g(r)dr dx = \int_a^b |_c^{f(x)} G(r) = \int_a^b G(f(x)) - G(c) dx = \int_a^b G(f(x))dx - G(c) $$
You forgot to apply the limits to the constant $G(c)$:
$$\int_a^b G(f(x)) - G(c) \, dx = \int_a^b G(f(x)) \, dx - G(c) \color{red}{\cdot (a-b)}.$$
Haha yes, thank you :)
FAQ: How to solve certain kind of integral
How do I solve an indefinite integral?
To solve an indefinite integral, also known as an antiderivative, you need to find the function whose derivative is the given integral. This can be done by using techniques such as integration by parts, substitution, or partial fractions.
What is the process for solving a definite integral?
To solve a definite integral, you need to find the area under the curve of a function between two given limits. This can be done by evaluating the integral using the fundamental theorem of calculus or by using numerical methods such as the trapezoidal rule or Simpson's rule.
How do I determine which method to use for solving a specific integral?
The method for solving an integral depends on the form of the integrand. For example, if the integrand includes a polynomial, you can use the power rule. If it includes an exponential function, you can use substitution. It is important to familiarize yourself with different integration techniques to determine the most appropriate method for a given integral.
Can I use a calculator or software to solve integrals?
Yes, there are many online calculators and software programs available that can solve integrals. However, it is important to understand the concepts and techniques behind solving integrals in order to verify the accuracy of the results and to gain a deeper understanding of the concept.
Are there any common mistakes to avoid when solving integrals?
Some common mistakes to avoid when solving integrals include forgetting to add the constant of integration when solving an indefinite integral, incorrectly applying integration rules, and not checking the limits of integration when solving a definite integral. It is important to carefully follow the steps and double check your work to avoid these mistakes.
