How to Solve for CosA and T in a Conical Pendulum?
To solve for CosA and T in a conical pendulum, the equations tcosA = mg and tsinA = mv^2/R are established, with R defined as LsinA. By substituting R into the second equation, T can be simplified. The relationship sin^2A + cos^2A = 1 allows for the elimination of sinA to express CosA in terms of T and other variables. The discussion concludes with the realization that this leads to a second-order equation.
sAXIn
Hello all , I encouter a problem solving this one :
We are given a conical pendulum with : V - tan. speed of particle
m - mass of rotating particle
g - gravity acceleration
L - leght of the string
We need to find CosA , T by what is given above !
A- is the angle between the string and vertical line !
So : I wrote : tcosA=mg
tsinA=mv^2/R
R=LsinA
but I can't present cosA without sinA or something
Please Help !
tsinA=mv^2/R
R=LsinA
That's fine. You can simplify and solve for T. Use the 3rd equation to eliminate R from the 2nd equation. Then realize that \sin^2\theta = 1 - \cos^2\theta.
okay got it I get 2nd order eq.
thanks a lot
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
