How to solve for i in compounding interest formula A=P(1+i)^n?
  • Thread starter Thread starter cjp88
To solve for i in the compounding interest formula A=P(1+i)^n, the correct approach involves using the formula (A/P)^(1/n) - 1 = i. In the example of doubling money from 1 to 2 over 5 years, substituting the values gives (2/1)^(1/5) - 1 = i. The error arises when not using brackets correctly in the calculator; entering 2^1/5 results in an incorrect calculation. The proper input should be 2^(1/5), which yields approximately 1.14869, leading to the correct interest rate of about 0.149. Proper bracket usage in calculations is essential for accurate results.
cjp88
I'm having some trouble understanding how to solve for i. This is the formula for compounding interest. I'm reading this example which shows how to solve for i if you double your money in 5 years. So it gives this example:
(A/P)^1/n - 1 = i
So it gives A for 2 and P for 1, n would be 5 so the answer should be:
(2/1)^1/n - 1 = i
They shown the answer as 0.149 however I cannot get this same answer for whatever reason.
When I put in 2/1 I get 2, then 2^1/5 would be 0.4, minus 1 would make it -0.6.
If this answer is indeed right, could someone please show me what I'm missing.
Mathematics news on Phys.org
2^\frac{1}{5} can't be 0.4, since (0.4)^5 is way smaller than 1 (since 0.4<1).
Since 0.4 = 2/5, you must've raised 2 to the 1th (which is two) and divided that answer by 5.
If you're using a calculator, be sure to put in the brackets correctly: 2^(1/5)-1.
I see what the problem was, I wasn't using brackets on my calculator. If I do 2^1/5 I get the wrong answer because it does 2^1 which is 2 then divides by 5 to get 0.4 instead of 2^(1/5) being 1.14869...
Thanks for the help on seeing my error.
Yes, if you just put in "2^1/5", your calculator interprets that as (2^1)/5 = 2/5= .4.
Use 2^(1/5) instead.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
