MHB How to Solve Second Order Damped Wave Equation for PDEs: A Comprehensive Guide
The discussion revolves around finding comprehensive resources for solving the second order damped wave equation, specifically addressing overdamped, underdamped, and critically damped cases. Participants express frustration over existing materials that often overlook the overdamped scenario or do not meet the required complexity for partial differential equations (PDEs). A suggestion is made to refer to MIT OpenCourseWare for relevant lecture notes, but the resource is deemed insufficient for the user's needs. The inquiry highlights a gap in available educational content that thoroughly covers all damping cases in the context of PDEs. A suitable resource that encompasses all aspects of the second order damped wave equation remains sought after.
Dustinsfl
Does anyone know where I find second order damped wave equation worked where the overdamped, underdamped, and critically damped cases are all taken into account?
I found resources where they throughout the overdamped and just focus on the underdamped.
Mathematics news on Phys.org
Hi dwsmith, :)
Are you trying to find an article where all the cases; over-damping, under-damping and critical damping are described? Then the following lecture note from MIT OpenCourseWare may help you.
http://ocw.mit.edu/courses/mathemat...monic-oscillators/MIT18_03SCF11_s13_2text.pdf
Kind Regards,
Sudharaka.
Sudharaka said:
Hi dwsmith, :)
Kind Regards,
Sudharaka.
Thanks but it isn't a high enough level example. I need one for PDEs.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
