MHB ็How to Solve the system of equation
  • Thread starter Thread starter Another1
    System
To solve the system of equations, start by dividing the second equation by the first, which eliminates x_0 and results in an equation involving only φ and γ. Next, divide the third equation by the first as well to obtain another equation in terms of φ and γ. This approach simplifies the problem and allows for easier manipulation of the variables. Solving these resulting equations will help determine the values of φ and γ. This method effectively reduces the complexity of the original system.
Another1
$$x_0\cos(\phi) = 2.78$$
$$x_0\sin(\phi)=2.78 \left( \frac{\gamma^2/2}{ \sqrt{10-\frac{\gamma^2}{4}}} \right)$$
$$x_0e^{-15\gamma} \cos\left(30\sqrt{10-\frac{\gamma^2}{4}}-\phi\right)=1$$
I don't know awsner of $$\phi , x_,\gamma$$
Mathematics news on Phys.org
Start by dividing the second equation by the first. That removes "[math]x_0[/math]" leaving an equation in \phi and \gamma. Then divide the third equation by the first to also remove x_0 and get another equation in \phi and \gamma.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
