MHB How to solve these 3 IQ practice questions?
  • Thread starter Thread starter JDW1
    Iq
JDW seeks help with three IQ practice questions involving age, averages, and ratios. The first question involves determining Jack and Jill's ages using simultaneous equations, where Jack is one and a third times Jill's age, and their combined ages total 119. The second question requires finding a third number when the average of three numbers is 19, and the average of two is 15, leading to a straightforward calculation. The final question involves sharing £450 in a 3:2 ratio, which can be solved by adding the ratio parts and calculating each person's share. These problems can be simplified through algebraic methods and careful calculations.
JDW1
Hi, I'm JDW, I've got three questions I had in this IQ revision test which I could not complete due to not knowing the method, I'll type questions below, I'm just looking for an explanation on how to answer them, thank you very much :D.
Jack is one and a third times as old as Jill. How old are Jack and Jill if their combined ages total 119?
The average of three numbers is 19. The average of the two of these numbers is 15. What is the third number?
Sid and Mary wish to share out £450,00 in the ratio 3:2 How much will each receive?
Mathematics news on Phys.org
I find that these word problems become much simpler if you "convert" them to letters and use algebra and write down everything the question tells us.
Jack is one and a third times as old as Jill[/color]. How old are Jack and Jill if their combined ages total 119[/color]?
Let Jack's age be $x$ and Jill's age be $y$.
The question tells us that $x = \frac{4}{3}y$ (the red text) and $x+y = 119$ (the green text)
This is now a straightforward simultaneous equation that can be solved using your favourite method. As a useful check make sure that $x > y$
Consider what the average is defined as - the sum of a set of values divided by the amount of values. In symbols $\displaystyle \mu = \frac{a+b+c+...+n}{n}$
Let your three numbers be a, b and c - you should be able to construct simultaneous equations and find the value you want.
Ratios are quite simple. Add the "shares" together (3:2) and multiply the initial value by the amount to be shared (450.00). As a check your values should add to £450.00
Hello, JDW!
Here's the second one . . .
Let the three numbers be a,b,c.
Their average is 19: .\frac{a+b+c}{3} \:=\:19 \quad\Rightarrow\quad a + b + c \:=\:57\;\;[1]
The average of two numbers is 15: .\frac{a+b}{2} \:=\:15 \quad\Rightarrow\quad a + b \:=\:30\;\;[2]
Subtract [1] - [2]: .c \:=\:27
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
