How to Solve Tricky Integrals Involving x^3*sin(x^2) and Rational Functions?
  • Thread starter Thread starter Lodve
    Integration
Lodve
Hi I'm struggling solving this integration:
x^3 * sin x^2
My idea to solve this one is to apply integration by parts, but I can't get through using it.
\frac{4x+2}{x^2(x^2+2)} this seems a hard nut to crack.
If you want to use integration by parts for the first one, there is a certain substitution that would make it quite simple. Can you see it?
Hmmm not sure, what if a let the u equal to x^2 and derive it so that I get 2x?
For integration by parts, I would start by breaking the product up into x2 and xsin(x2).
u=x^2
du=dx*2x
so your argument would be:
1/2u*sin(u)du
which is easier to do parts on.
For the second integral, use Partial Fraction Decomposition:
<br /> \frac{4x+2}{x^2(x^2+2)} = \frac{Ax+B}{x^2}+\frac{Cx+D}{(x^2+2)}<br />
Each of the resulting fraction could be integrated by u, du substitution.
http://en.wikipedia.org/wiki/Partial_fraction
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
