How to test for a purity of a chemical compound
  • Thread starter Thread starter brajesh
    Chemical Test
Testing the purity of a chemical compound, such as C15H11I4NO4, is complex and requires specialized knowledge and equipment. The discussion highlights that there is no universal test for purity; it depends on the specific impurities of concern and their acceptable levels. A common method suggested is thin layer chromatography (TLC), which can indicate whether a sample is a single compound or a mixture. However, the resolution of the chromatography may not always be sufficient to confirm purity definitively.The conversation also emphasizes that most medical drugs are not supplied in pure form, often containing various excipients or carrier liquids that can complicate purity assessments. It is advised to obtain medications only from recognized medical suppliers or pharmacies to ensure safety and quality. The risks associated with sourcing drugs from alternative suppliers are significant, including the potential for incorrect dosages or harmful impurities. Overall, the consensus is that testing for purity is a complicated task best left to professionals in a laboratory setting.
brajesh
TL;DR
If you had this chemical compound, for example, how could you test if its pure?
$$C_{15}H_{11}I_4NO_4$$
Chemistry news on Phys.org
That is not a compound, it is a formula. There are numerous possible compounds with the same formula.
There is no "test for purity". It depends what possible impurities you are interested in, and at what level.
Likes brajesh, Vanadium 50 and russ_watters
In my case, I'd take a whole bunch of chemistry classes. Then I'd understand what to do and what not to do; I'd understand the complexity of the problem. I wouldn't just jump into it looking for a simple solution to implement that someone else understands. I'd also have to have a chemistry lab to work in. Things you might need, like spectrometers and reagents, are expensive. But then, IDK, I'm definitely not a chemist.
Likes brajesh
If you have a sample of something you can always try find a solvent that dissolves it (might need some trial and error) and run relatively easy and cheap TLC (thin layer chromatography) to see if it splits - that will at least suggest whether you deal with a single compound, or a mixture. One can argue that mixture is never "pure" while single compound is.
But as others already wrote testing for purity is in general quite a complicated task, requiring plenty of knowledge and often quite an expensive hardware.
Likes brajesh
Hey that's an interesting idea.
If I have a real sample, and a "test" sample, then I wonder if I do a TLC, the chromatograms should be identical? Could that work?
brajesh said:
Summary:: How to test for a purity of a chemical compound
Why did you ask specifically about that drug?
Closely related compounds (like, for example, two thyroid hormones) can have similar chromatographic retention times. If they separate into multiple peaks, then you definitely have a mixture, but if they give one peak, then all you can say is that either it’s pure or the chromatography technique doesn’t have enough resolution (theoretical plates) to separate the mixture.
For a friend, because of the impacts of the war, the drug is in short supply and she wants to source via alternative sources she but can't be sure of the quality.
Likes berkeman
The only reliable source of a drug is from a pharmacy or medical suppliers who service pharmacies.
AND
Normally no medical drug is supplied pure. If it is a tablet there will be the solid materials that form the tablet, a coating to colour the tablet for recognition purposes (but there are more features than just its colour to help its recognition, such as a particular shape and standard marks or groves on it). Sometimes a sweetener is added to mask unpleasant tastes.
If it is supplied in liquid form for ingestion or injection, the vast bulk of the sample will be the carrier liquid, there might be a preservative present, it might not be a particularly soluble substance so it could have other things present to help it dissolve in the carrier liquid. Something to prevent it irritating the veins if it is injected or sweeteners if it is taken orally.
Often the active ingredient is present in very small amounts in the medicine you use, less than 5% is not unusual.
So you will almost never come across a pure drug being used or sold. So just forget buying a drug from some source that is willing to sell directly to a random person, and your efforts to test it for "purity" are doomed to failure. Only ever get something for medical use from a recognised medical supplier or pharmacy. And even a medical supplier is risky, as they might be selling the drug as a pure or nearly pure sample, ready to be manufactured into tablets or a usable liquid form. IE it could be 10s or 100s of times stronger than in normal tablet or liquid form. And you could even end up with the wrong isomer of the drug!
I strongly suggest that you forget this approach. Or someone might end up dead.
PS the chances of you finding a reliable "alternative" source of C15H11I4NO4 look somewhat unlikely to me. I can't see why some companies would make a thyroid treatment for any other purpose, and it is patented so it is likely only some places make it.
And I find the idea of searching for an "alternative source" of a drug somewhat worrying.
Likes russ_watters, DaveE, berkeman and 1 other person
And with that excellent post by @DrJohn this thread is now closed.
  • · Replies 46 ·
