How to understand Proton Structure-function (pdf)
  • Thread starter edfink234
  • Tags
    Pdf Proton
In summary, the attached image shows the structure-function of a proton at different scales of resolution. At low energies, the proton can be described as a point-particle with a Coulomb potential. As the energy increases, the proton is seen to have a charge distribution, and at even higher energies, it is found to consist of 3 point-like constituent quarks, as well as sea quarks and gluon fields. However, these images only depict probabilities for certain types of particles and do not fully capture the complexity of a proton's structure. To fully understand the structure of a proton, three-dimensional images are needed to show all possible particles that could be produced. Additionally, the depiction of gluons in the third image should curve towards the
edfink234
I don't understand the attached image, which shows the structure-function of the proton, for the cases of
1. point-like particle
2. 3 non-interacting quarks
3. 3 quarks interacting via gluons
4. valence and sea quarks interacting via gluons
Can someone please explain this to me? I would greatly appreciate it.
The vertical axis is the structure-function for a fixed Q^2, the horizontal axis is the Bjorken x.
Likes ohwilleke
What have you read about the subject? Which part do you have difficulty understanding?
The best place to start is a textbook. You are basically asking us to write textbook material here.
Likes vanhees71 and mfb
My very limited knowledge: 4 is complete description.
The four images depict descriptions on different scales of resolution the partonic structure of the proton. It's investigated in scattering of electrons on a proton. The higher the scattering energy is the more "microscopic details" of the scattering object is revealed. At low energies one can well described the scattering as Coulomb scattering, i.e., describing the proton by a point-particle Coulomb potential. At somewhat higher energies one finds that there is a "form factor", i.e, a deviation from a pure point-particle Coulomb potential indicating that the Proton is an extended object with a corresponding charge distribution. Going even higher in energy, one finds a cross section that is explained by the assumption that the proton consists of 3 point-like constituent quarks. Going even higher reveals that there are also sea quarks and antiquarks. From QCD it's also clear that there must be gluon fields too, and in fact QCD has been discovered from the investigation of this deep inelastic scattering of electrons and protons (starting with the discovery of Bjorken scaling at SLAC and Feynman's explanation in terms of the "parton model").
Part of the problem is that the two dimensional chart is a depiction of a data set that is more than two dimensional. Each chart depicts probabilities for only one particular kind of parton. For example, what is the probability that if we smash a proton that a muon will come out. But this is only a tiny part of the total picture of what is going on inside a proton and could come out of one if you "poke" it.
To capture the full structure of a proton, you need something more like the images that appear behind the charts (ideally in three dimensions, although symmetry considerations make the two dimensional images less bad than they would be otherwise), that depict every possible kind of particle that could be produced, all at once.
Also, just to be fussy, if you are really going to do an image like the third one correctly, the lines that depict gluons between the valence quarks would curve towards the center, because they have found that gluons are concentrated in the middle of a proton rather than closer to its edges.
Likes vanhees71
FAQ: How to understand Proton Structure-function (pdf)
What is a proton structure-function and why is it important to understand?
A proton structure-function refers to the internal composition and behavior of a proton, which is one of the fundamental particles that make up an atom. Understanding the structure-function of a proton is crucial in understanding the behavior and properties of matter, as protons play a significant role in the structure of atoms and the interactions between particles.
How is the structure-function of a proton studied?
The structure-function of a proton is primarily studied through experiments using high-energy particle accelerators, such as the Large Hadron Collider. These experiments involve colliding particles with protons and analyzing the resulting interactions and particles produced. The data collected from these experiments is then used to create models and theories about the structure-function of protons.
What are the main components of a proton's structure-function?
The main components of a proton's structure-function include its mass, charge, spin, and subatomic particles such as quarks and gluons. These components work together to determine the properties and behavior of a proton, such as its stability and interactions with other particles.
How does understanding proton structure-function contribute to advancements in science and technology?
Understanding proton structure-function has led to many advancements in science and technology, particularly in the field of nuclear physics. This knowledge has helped scientists develop new technologies, such as nuclear energy and medical imaging techniques, and has also contributed to our understanding of the origins and evolution of the universe.
Are there any current theories or models that explain proton structure-function?
Yes, there are several theories and models that attempt to explain the structure-function of protons, such as the Standard Model of particle physics and Quantum Chromodynamics (QCD). These models are constantly being tested and refined through experiments and research, and there is still much to be discovered about the structure-function of protons.
