High School How to use magnets in levitation?
  • Thread starter Thread starter woodturner
It is possible to float a wooden lid over a box using magnets without an electric power source, though it presents challenges. To achieve this, the rim of the box should be lined with north-up facing magnets, while the lid's edge should feature north-down facing magnets, creating a shallow magnetic bowl effect. This configuration helps maintain the lid's horizontal position with the assistance of gravity. However, the floating effect can be easily disrupted by misalignment or side forces. For added stability, making the lid circular and spinning it may enhance the levitation effect.
woodturner
How did you find PF?: google search
I wish to find out if its possible to float a wooden lid over a box using magnets. without using electric power source,if so how?
It is possible - but tricky.
I would try lining the rim of the box with north-up facing magnets.
Then I would line the edge of the lid with north-down facing magnets.
The lid magnets should outline a slightly smaller area than the rim magnets - so when the lid is on, it is sitting in a shallow magnetic bowl. That way, gravity will assist in keeping the lid horizontally positioned.
The problem will be that the repulsive force keeping the lid floating can be readily disrupted by side forces created when everything isn't aligned well.
If I recall correctly you have to make the lid circular and spin it.
Topic about reference frames, center of rotation, postion of origin etc Comoving ref. frame is frame that is attached to moving object, does that mean, in that frame translation and rotation of object is zero, because origin and axes(x,y,z) are fixed to object? Is it same if you place origin of frame at object center of mass or at object tail? What type of comoving frame exist? What is lab frame? If we talk about center of rotation do we always need to specified from what frame we observe?
