B How to use the Binary Mass Function for exoplanets?
  • B
  • Thread starter Thread starter Astroxzip
    Exoplanets
The discussion centers on calculating the mass of the exoplanet KELT-8b using radial velocity values, with confusion surrounding the binary mass function and its units. The user initially assumed solar masses as the unit but obtained an incorrect mass of 3.48 solar masses, diverging from established findings. Clarification is sought on how to properly interpret the radial velocity curve and condense the data for accurate mass calculations. The binary mass function is noted to constrain the mass of an unseen component in a binary system, but its unit definitions remain unclear. The user is encouraged to refine their method of averaging radial velocity values to improve accuracy in their calculations.
Astroxzip
TL;DR Summary
Hi. I am working on a research paper for my high school and I am trying to calculate the mass of an exoplanet using the radial velocity values of its star. However, I am confused as to the binary mass function and what units you would use. I also wanted to know how you would interpret a radial velocity curve to calculate the mass of the exoplanet. Thank you
The paper I am using for my radial velocity values is the following (Table 4)
https://iopscience.iop.org/article/10.1088/0004-637X/810/1/30
Hi. I am working on a research paper for my high school and I am trying to calculate the mass of KELT-8b using the radial velocity values of its star. However, I am confused as to the binary mass function and what units you would use. I was under the impression you would use solar masses however I am getting a mass of 3.48 solar masses which is nothing close to the mass they found in the paper. I also wanted to know how you would interpret a radial velocity curve to calculate the mass of the exoplanet because I figured maybe I found the radial velocity the wrong way. The way I did it was by taking an average of the peaks after graphing it against the time. Thank you
Astronomy news on Phys.org
Here is how to find how something is defined in a scientific paper.
  1. Look for a definition in the paper.
  2. If there is no definition, look for a reference to what you are looking for. Get that paper.
  3. Look for a definition in that paper.
  4. Repeat as needed.
Hi. I know how they have defined the radial velocity values. The problem is I do not know how the binary mass function works and what units you need for the function.
The phrase "binary mass function" does not appear in the paper you cite. Where did you come across the term and how is it defined?
Likes Vanadium 50
Ok so, basically the paper I am writing needs me to calculate the mass using radial velocity method. After doing some research, I found the binary mass function in an Astrophysics textbook which I found could work for exoplanets. However the problem is that the units are not defined anywhere which is the main source of issue. As for how it is defined, the binary mass function constrains the mass of the unseen component of a binary system, which in my case is the mass. As for the paper I cited, I used it for the values of the radial velocity, however I am struggling a bit to understand how to condense them into one for my calculations. I ended up taking an average of the five highest values however I think my answer could have deviated due to the method I chose to condense the radial velocity values into one.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
How does light maintain enough energy in the visible part of the spectrum for the naked eye to see in the night sky. Also, how did it start of in the visible frequency part of the spectrum. Was it, for example, photons being ejected at that frequency after high energy particle interaction. Or does the light become visible (spectrum) after hitting our atmosphere or space dust or something? EDIT: Actually I just thought. Maybe the EM starts off as very high energy (outside the visible...
