How to use wolfram alpha to plot frequency response
To plot the magnitude and phase response of the transfer function H(s) on Wolfram Alpha, users can utilize the functions abs(...) and phase(...) with the imaginary unit i. For phase plotting in degrees, the 'bode(...)' function is recommended, which also provides additional plots like Nyquist and Nichols. Users expressed appreciation for the guidance, noting its practical application. There is a learning curve for understanding concepts like Nyquist and Nichols, but the tools provided are seen as beneficial. Overall, the discussion highlights effective methods for frequency response analysis without Matlab.
Void Xylem
Can someone please tell me how I can plot the magnitude and phase response of this transfer function on wolfram alpha as I don't have Matlab:
H(s) = -(2.1953*10^12)/(66600*((j*ω)^2)+808823539.4*(j*ω)+2.1626*10^12)
A link to the output would be very useful also, thanks heaps.
You can use abs(...) and phase(...) with i as the imaginary unit.
thanks bro, your post has improved my life quality by a factor of 0.0001, one more question: How do I make it plot the phase in degrees instead of radians.
You can also use 'bode (...)', which will plot the amplitude and phase in degrees. As a bonus you get Nyquist and Nichols too :)
haha wow that's really cool, its going to be very useful, i got to admit i have no idea what the Nyquist and Nichols are atm but ill get there eventually. thanks for the help.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
