How to wind a brushless motor (number of windings per stator)
To wind a brushless motor stator effectively, it's essential to determine the number of windings based on the desired performance and specifications. Key factors include the number of poles on the rotor, required RPM, and power output. Calculations for winding involve understanding the relationship between these elements and the copper wire used. Providing a picture of the stator can help clarify the winding process. Accurate winding is crucial for achieving optimal motor performance.
oystein
Hi folks,
I'm searching for information/procedure and also calculations/equations on how to correctly wind a stator on a (general or DC 3-phase) brushless motor? I.e. how to wind a copper wire X number of times around the stators, and thus get the desired performance/force that is required?
Thanks in advance!
Welcome to PF.
Can you please give a link to, or attach a picture of the stator.
How many poles on the rotor?
What RPM do you need?
What power?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
