I How to work in the |F,m_F> states in hyperfine structure
lelouch_v1
TL;DR Summary
A little confused about the notation in the coupled and uncoupled basis
Suppose that we have two atoms with one proton one electron each, and these electrons interact with each other. The states for the electrons are the singlet(S=0) and the triplet states(S=1). My question is if i have to keep the nuclear spin of the protons parallel when i write the states, for example $$\frac{1}{\sqrt{2}}(|+-\rangle-|-+\rangle)_e\otimes|\Uparrow\rangle_p$$
for the singlet state, and if so, can i use the fact that F=S+I, which in this case whould yield the state |1,1?> ?(S=0,I=1/2+1/2=1,ms=0,mI=1)
If you have two protons, then you also have to write the spin state of the protons in term of singlet and triplet states.
Thank you for your answer. I thought of that as well, but that would lead to having 16 states in the uncoupled basis, and in the coupled basis we would have $$|2,M_F\rangle \ \ \ , \ \ \ |1,M_F\rangle \ \ \ , \ \ \ |0,0\rangle$$ which yields a 9X9 matrix. The problem with that is that the author of the paper that i am reading (it's on the radical pair mechanism) states that there are 8 eigenvalues of the hyperfine hamiltonian, meaning an 8X8 matrix, so i suppose that he always takes the proton spins to be parallel (either both spins up or both down).
Can you give the reference?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
