How Transmission Lines Transposition could affect Protection systems?
Transposition of transmission lines is crucial for balancing impedance and minimizing unbalanced voltages in long AC transmission systems. It helps reduce inductive coupling between adjacent lines, which can affect protection systems by altering current flow and fault detection. Non-transposed lines may lead to increased coupling and potential misoperation of protection mechanisms. The discussion also touches on the differences between transmission lines and waveguides, particularly regarding the support of TEM waves. Overall, understanding transposition is essential for effective power system evaluation and protection setup.
Luichip
I would like to know if Transposition on Transmission Lines could affect the basis and the way the power system is evaluated to set up the protection for the Transmission line? as compared to the non-transposed Transmission Lines.
Thanks in advance,
Regards,
Are you referring to the fact that an open circuited quarter wave line will present a short circuit at the input? (etc.) It's enough of a problem to make it worth while using DC for long distance power transmission.
I'm Talking about Long AC Transmission Lines, not DC in this case. Thanks.
Transposition is done regularly in long AC transmission lines as a means of balancing transmission line frequency impedance and admittance in a long line, and that contribute to unbalance voltages. This is usually done in double circuit AC long transmission lines...
I want to why TEM waves are not supported by transmission lines? and where is the point of difference in using waveguides and transmission lines?
Thanx in Advance.
They do. See http://en.wikipedia.org/wiki/Transmission_line
This is why RG-8 has a characteristic impedance of Z=50 ohms, for example.
Bob S
Transposition of individual conductors in a long AC transmission lines can minimize the inductive coupling to proximal lines. See refs 23-25 by Firestone and (Barney) Oliver on page 553 in
http://astro.berkeley.edu/~greg/isnumber=24903&prod=JNL&arnumber=1126050&arSt=+544&ared=+558&arAuthor=+Cristal%252C+E.G.%253B++Young%252C+L.pdf
If the lines are not transposed, loss of current in one line will inductively couple to the other lines.
Bob S
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
