How Were Emission Lines Observed in Different Spectra Ranges?
  • Thread starter Thread starter jonlg_uk
    Series
The discussion centers on how scientists like Lyman and Paschen observed emission lines in the ultraviolet and infrared spectra, respectively. It highlights the use of instruments beyond the human eye, such as photographic plates sensitive to various wavelengths, including ultraviolet and infrared. Participants speculate on the experimental setups used by Lyman and Paschen, suggesting that higher frequencies required emulsions with greater silver content. The conversation emphasizes the historical context of these observations and the technological advancements that facilitated them. Understanding these methods is crucial for appreciating early spectroscopic techniques.
jonlg_uk
If the Balmer series describes the emission lines produced when hydron atoms are electrically excited when subjected to visible light, the eye can visibly see these lines. How did Lyman do do for the ultraviolet spectrum, how did he observe emission lines for the ultraviolet spectrum and how did paschen do it for the infrared spectrum?
Scientists use other instruments to measure quantities besides the human eye, you know! How do you think doctors read x-rays? With super-powers? No, a machine does it for them, then creates an image for the doctor to see. The image is a visible light representation of the x-rays
I know that!...I want to know how they did it back then. How did Lyman and Paschen do it and what was there experimental setup.
One type of detector could be photographic plates.I'm assuming that back in the day of Lyman and Paschen there were photographic emulsions sensitive to I.R as well as to light and emulsions sensitive to U.V, X rays and gamma rays.I think the higher the frequency to be detected the greater the silver content in the emulsion.
I too was thinking something like this. It would be great if someone could confirm it.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
