How wide is a single slit that gives its first minimum at 90°?
The discussion centers on determining the width of a single slit that produces its first minimum at 90 degrees. The equation provided, øp = p(λ/a), is key to solving the problem, where øp represents the angle, p is the order of the minimum, λ is the wavelength, and a is the slit width. The user is uncertain about how to express the relationship in a formula and seeks clarification on the variables involved. Guidance is offered to express the answer in terms of λ, emphasizing the importance of understanding the equation's components. Overall, the conversation highlights the need for a clearer grasp of the underlying physics to solve the problem effectively.
jmacmartin
øp=p(λ/a)
Not quite sure what the answer is looking for but I'd guess I would need to solve for "a." So...
90°=(λ/a)
Is there any more information I can gather from this problem? Any guidance would be a big help.
Thanks guys!
Hello JMM and welcome to PF,
The answer isn't looking for anything. You've given a problem statement, but suppose I didn't know any of the symbols appearing in your equation; then: how could I help you ?
Do you know what the answer is to "How wide is a single slit that gives its first minimum at 30°?" or 45 or 60 ? Can you express that in a formula ? Then moving on to 90 shouldn't be too dificult, right ? Or... ?
Hi BvU,
I do not know the answer to that question. No matter the angle, I'm not quite sure how to express it in a formula. I apologize if I have not asked my question in the proper form for this website.
I know the equation øp=p(λ/a) will tell me where the dark bands are on the screen. I assume øp = 90 since that is given. I do not know λ. It appears I need to solve for a, which is the width of the slit.
Let me rephrase:
What is ø and what are the units ?
What is p and what are the units ?
What is λ (ok, the wavelength in m)
What is a and what are the units ? Ah we know now: the width of the slit. Also in m.
Your expression doesn't look like what I see coming by when I simply google the title of this post. So it comes from your book or your notes, right ? What is it based on ?
(Note that in many treatments a small-angle approach is used, where ##\sin\theta=\tan\theta=\theta##. This is something you can't have in this exercise!)
In an exercise like this, it is OK to express the answer in units of λ .
Oh, and:
makes me wonder where in the equation the multiplicity ("dark bands") appears?
Sorry to waste your time with stupid questions. I will seek help elsewhere.
I'm fully prepared to provide the best possible assistance. But your cooperation is indispensible.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
