How would dark matter aggregate?
In summary, dark matter is thought to aggregate around galaxies, but it's not clear how it does so. One possibility is that it loses energy when it interacts with normal matter, and this leads to galaxy formation. Another possibility is that the dark matter starts clumped for some reason, and this leads to galaxy formation.
  • #36
mrspeedybob said:
You beat me to it.
The other thing that I was going to ask is, how do we know dark matter does not radiate? We know it doesn't radiate EM because we can't see it, but what's wrong with the idea of another force or type of radiation that interacts with dark matter and not normal matter. DM had to come from somewhere. If I understand correctly, normal matter condensed out of primordial EM radiation, so it makes sense that there has to be some interactivity between the 2. DM could not have condensed out of EM because EM does not interact with it. Soo, isn't it at least plausible (if not likely) that there's another form of energy that DM does interact with?
You are asking if there is some other whole set of things in physics that no one knows about. Doesn't that seem unlikely to you? What kind of radiation do you image that would not be EM radiation?
Space news on Phys.org
  • #37
The only way we know about dark matter is because of its gravity. If there were a massless particle (like a photon) that didn't interact with the stuff that we and our instruments are made of, it wouldn't be surprising if we didn't know about it. The only way we could would be if it were needed to explain the behavior of dark matter, and that's hard enough to measure.
  • #38
And if it didn't interact with "the stuff that we and our instruments are made of" how would it EVER be known to exist and why would it matter since it doesn't interact with anything?
Dark matter is of unknown composition. I think trying to introduce another very hypothetical item to try to explain it doesn't seem very helpful.
  • #39
I've read through this thread but I'm surprised not to hear more mention of gravitational waves. Gravitational waves are are the simple answer to the OP's question. (at least according to my high-energy physics textbook). [Edit: I mis-read or mis-remembered what I studied. Corrections made below after double checking.]
Even ignoring baryonic matter for the moment, assuming there are some slight fluctuations in dark matter density in the early universe (i.e., nearly uniform, but not quite), clumps of dark matter would collapse on themselves. But similar to how @haruspex has already mentioned, if our universe obeyed Newtonian gravity, those clumps would merely oscillate indefinitely, getting smaller then bigger, then smaller again and bigger again, and so on and so on, without end. Where did the energy go?
Gravitational waves. A galaxy or even galaxy cluster sized [in terms of mass] chunk of dark matter would produce jaw dropping amounts of gravitational waves from the oscillations as it collapsed and oscillated. These gravitational waves radiate away from the center leaving less energy in the system than when it started.
[Edit: The chaotically varying gravitational field adds an additional heating component to the baryonic matter besides that of the adiabatic heating. That heat is then released by the baryonic matter in the form of photons.]
Eventually the oscillations die out when the system becomes virial, and the shape of the clump becomes stable over time. Dark matter particles (assuming WIMPs) have greatly varying speeds relative to each other, but on large scales, the shape of the ensemble remains constant. Since the shape of the clump is now constant, you no longer get appreciable gravitational wave generation.
Add that tiny bit of baryonic matter into the mix, and it doesn't change a whole lot. The baryonic matter just goes along for the ride.
The interesting question is whether the supermassive black holes at the center of galaxies simply came from the mergers of many stellar sized black holes or if the galaxy's initial collapse and oscillations (before virialization) played a more significant role. I don't know enough about the subject to comment on that, so I'll end it there. (It's not really part of the OP's question anyway).
But for a simple answer,
haruspex said:
That doesn't explain the loss of energy. If the dark matter started (roughly) uniformly spread over the vastness of space, the KE when trapped in orbit in a galaxy is only half the lost PE. Where did the rest go?
you needn't look any further than gravitational waves heating of the baryionic matter within a chaotically changing gravitational field. They [photons] carried the energy away.
Likes PhanthomJay
  • #40
Gravitational waves can only carry off a miniscule amounts of energy, save for interactions between compact bodie [like black holes].
  • #41
Also, it is not true that density fluctuations will lead to significant contraction automatically. What one expects adiabatically (no energy transport) is simply pressure waves-- that's more or less what sound is. Adding gravity to the mix won't do much, because gravity only gives the compressed gas even more of an excess kinetic energy than adiabatic compression gives it-- it bounces back even more readily. To get a normal gravitational instability, called the Jeans instability, you need heat transport. Indeed, the Jeans instability is a constant temperature instability. But how dark matter would enforce isothermality I have no idea-- maybe conduction? Or some form of dark radiation, as speculated above? The paradox is, it seems to me that to get dark matter to contract first, it needs to be quite good at energy transport, yet we tend to think of it as poor at that. Since I don't know, I regard the OP question as still unanswered here, and perhaps unanswered everywhere.
  • #42
Now that I double check, you are right. Allow me to make a correction. The baryonic matter is heated during virialization, due to a chaotically varying gravitational field that's likely to be the main contributor. The bulk of the energy is carried away by the electromagnetic radiation as the baryonic matter radiates photons (rather than being significantly carried by gravitational waves).
Let me just quote from my textbook. Peter Meszaros "The High Energy Universe", Cambridge University Press, 2010, pp. 49, 50.
The most important aspect of the process is that after the epoch of matter-radiation equilibrium, most of the mass-energy is is the form of dark matter, and even before recombination (i.e., before the electrons recombine protons to make neutral atoms), the dark matter dominates the gravitational field of the Universe and also that of any density perturbation in it [20]. Since the dark matter does not "feel" the radiation, regions with an excess of dark matter relative to the background start to slow down and eventually recollapse (see Fig. 4.1). The dark matter is, from all indications, non-relativistic; that is, it has no pressure. Thus when dark matter particles recollapse onto themselves, they are not stopped by their own pressure (they are "collisionless") and they go right through each other. They overshoot, and like a pendulum, eventually they turn around and around again. In the process, the gravitational field varies chaotically, and this acts as a damper on the dark matter motions, which come to a quasi-thermal equlibrium in a few dynamical times satisfying the Virial theorem, which states that twice the kinetic energy of the particles equals their gravitational potential energy. This process is called virialization, the equilibrium outer radius being half the radius at turnaround.
What happens during all of this with baryons? The baryonic gas is a smaller fraction of the total mass than the dark matter (DM) and its dynamics is dominated by the gravitational field of the DM. Thus, the baryons initially follow the DM during the expansion, the turnaround and the early phases of collapse. As the collapse proceeds , the volume ocupied by the DM and the gas decreases and both are adiabatically heated. However, unlike DM, the baryonic gas is collisional (i.e., its atoms have a significant "cross-section" for interacting with each other as the gas density increases in the collapse), and this gives rise to further heating cause by collisions between blobs of baryonic gas leading to shocks which convert the infall kinetic energy into random thermal motion energy of the particles. These thermal gas motions lead to collisions between individual atoms and molecules, which excite their electrons to higher quantum energy levels followed by radiative de-excitation; that is, the emission of photons.​
  • #43
Yet what that doesn't explain is how dark matter aggregates. Saying dark matter obeys the virial theorem is exactly the problem, that's what requires heat transport to allow contraction because the virial theorem means that contraction induces an excess of kinetic energy over what could sustain the contraction in the long run. So you'll never get a cosmic web of virialized dark matter unless you give the dark matter the ability to transport heat, and that's the part I don't understand.
Likes Laurie K
  • #44
Virialization doesn't require energy loss. It generally just involves the randomization of the orbits of the various objects/particles so that they're in approximate thermal equilibrium with one another. Dark matter can do this through gravitational interactions which exchange momentum between different particles.
Likes collinsmark
  • #45
Ah yes, that's a good point-- so all you need is for the dark matter to get a significant overabundance of (negative) gravitational potential energy, and it will want to contract and convert that into kinetic energy as it virializes. That makes sense, so you don't need heat transport, you just need dark matter on a large enough scale, which you certainly have.
  • #46
Is it necessary for this dark matter to act as a gas? Isn't the presumption that dark matter particles don't even interact with other dark matter particles? If that is so, it is not a gas in the sense or exerting pressure or following other gas laws.
If DM is that inert, then most dark matter particles entering our galaxy will retain galactic escape velocity and eventually pass through; and some will lose enough energy through gravitational effects to stay.
There is one interaction that dark matter should be exceptional at - diving into a black hole. If their trajectory is right, nothing electromagnetic will stop them from diving right in. And, as they enter, they shouldn't be able to radiate much except in the form of gravitational waves.
Speaking of interactions, is DM presumed to be either Fermions (affected by Pauli Exclusion) or Bosons (possibly forming a condensate) ?
  • #47
Sure, but that is not going to give you ongoing aggregation, which was what the original question concerned. It just gets you from a static spread at one radius to a chaotic sphere at a smaller one, the lost PE having been turned into KE. I am prepared to take on trust that the gravitational interactions make a chaotic sphere unstable, leading instead to a much flatter structure, but still asymptotically of a great radius.
The answer to that original question appears to be that it indeed does not continue to aggregate, other than by leaking KE to slower moving baryonic matter through the gravitational interactions.
  • #48
An ideal gas assumes non-interacting particles in thermal equilibrium with one another. So yes, dark matter can be modeled very well as a gas.
There are dark matter candidate proposals for both of these possibilities. Axions are one possibility for bosons, while the neutralino is a fermion that exists in supersymmetric models and is another candidate.
  • #49
I don't think that's accurate. My understanding is that you only get a flattened structure in the presence of friction, so dark matter won't ever do this to any appreciable extent.
  • #50
I only said I was prepared to believe that. It could be a bit like a spinning block only being stable about two of the three axes. Chaotic gravitational interactions might make a basically spherical shape unstable. Or perhaps it becomes unstable in the presence of the baryonic matter having assumed a disc structure.
If that is not correct then the large scale membranous structure of DM becomes another puzzle.
  • #51
If there is any residual angular momentum after virialization, the clump of dark matter would form an oblate spheroid [Edit: technically, a halo having oblate spheroid-ish symmetry]. My understanding is that this agrees with observation in our Milky Way galaxy; that is, even though the baryonic matter is mostly in the shape of a flat disk, the dark matter halo part is much thicker: not quite spherical, but much closer to spherical than the baryonic matter (i.e., the dark matter halo is oblate spheroid shaped).
  • #52
You're looking at it backwards. The dark matter doesn't clump around galaxies, the galaxies form in dark matter clumps. There is five times as much dark matter as matter. I like to think of galaxies as little blobs bobbing around a huge dark matter cloud.
  • #53
That's unclear. DM doesn't clump as well as the regular stuff. Except with black holes, it does elastic collisions - or no collisions at all. So it would be much better at intergalactic (or inter-clump) cruising.
On the other hand, we have one example of a 99% dark matter galaxy and no certain examples of a similar regular matter galaxy. Makes me wonder if that 99% DM galaxy is a fragment separated from another galaxy.
  • #54
It is widely thought that you need dark matter clumping to get baryonic matter clumping to happen faster. One of the reasons the dark matter model rose to the fore is that models of pure baryonic clumping could not get galaxies to appear fast enough. So the "cosmic web" is very much a dark matter phenomenon, that pulls the baryons into compliance. It seems the dark matter clumping can be explained simply by virialization on large enough scales such that there is enough gravitational potential energy to convert into kinetic as the contraction plays out. Why it makes filaments instead of spherical clumps is another thing we need to understand-- I don't know why the contraction is more two-dimensional than three dimensional.
  • #55
For example, if we detect that DM is cooling, that would be an indication there are some significant self-interactions in DM sector. There can be "dark photons"
Well, we do want eventually understand what that stuff is. Just leaving it as "unknown uncharged heavy particles" is not good enough.
  • #56
But since we don't know what DM is, why posit an extra unknown to explain a characteristic of something we already don't know enough about?
I agree.
  • #57
I visualize it as follows.
Imagine an expanding universe with uniform, motionless (in comoving coordinates) dust. This is not gravitationally stable. Dust will start to clump, start to "fall into" randomly shaped regions. If dust is non-interacting, dust particles will accelerate, pass through the center of "their" overdense region, then decelerate. Ones which move a bit faster than on average will escape from this clump... and fall into the next, while expansion of Universe makes their velocity relative to this other clump smaller.
Dust particles which do not escape, they fall back into the clump, and will generally stay orbiting it. (Some will still escape on further revolutions).
With initially motionless dust, the result is very clumpy.
If initially dust does have some random velocities, not too large, the clumps would still form but they can't be small: dust moves too fast to form small ones. The "hotter" it is, the larger this lower clump size limit.
Evidently, the observed DM in the actual Univrse does clump only on large scales (at least galaxy-scale). It should be possible to estimate its random velocity distribution from this.
  • #58
I just explained to you that if, in your words, "it didn't interact with 'the stuff that we and our instruments are made of'", there are still possibilities to get more information about it indirectly. It's possible to indirectly observe that DM's random velocity ("temperature") is decreasing. If something like this will be seen, it needs to be explained.
  • #59
nikkkom said:
For example, if we detect that DM is cooling, that would be an indication there are some significant self-interactions in DM sector. There can be "dark photons".
Yes, it would be interesting to be able to determine if the degree of dark matter clumping is pure virialization at a given scale, or if it requires some additional heat loss to get that much contraction. I don't know what the models are saying about that at present.
  • #60
Likes .Scott
  • #61
That first article raises more questions in my mind. First of all, the article claims that the speed of the dark matter particles was expected to be a few millimeters per second, but now they are saying 9 km/s. How they think 5 orders of magnitude difference in speed could have been hidden all this time is really beyond me, but an even deeper question is, how do they think they can go from a thermal speed to a temperature? From where I'm sitting, the temperature is still proportional to the particle mass, even if you know the thermal speed, so how do they claim a temperature of 10,000 K? They seem to be assuming the particle mass is like that of a proton, but where do they get that from?
  • #62
DM particles are not directly detectable (yet?), thus no direct measurements of their velocities exist.
Wrong.
Temperature is simply the mean kinetic energy. A "soup" of particles whizzing around with 1eV of mean kinetic energy corresponds to temperature of ~11000 Kelvin.
To go from temperature to velocity (or vice versa), you also need to know the mass (or distribution of masses) of the particles. Lighter particles move faster at the same temperature.
If we assume that DM particles were at equilibrium with the rest of the plasma early during Big Bang, then, if DM particles are heavy, they moved (relatively) slowly at decoupling; and if they are light (like ordinary neutrinos are), they moved much faster. In both cases their velocities then decrease during expansion of the Universe.
For neutrinos, unless we missed something in our BB models, expected decoupling time is ~1 second after BB, expected temperature of neutrinos today is 1.95 K, which is ~0.2meV of kinetic energy. Since neutrino rest masses are comparable to this energy, it means that neutrinos are still moving relativistically and can't explain dark matter observations.
https://en.wikipedia.org/wiki/Cosmic_neutrino_background
  • #63
Of course, yet they know the matter distribution fairly well, and the claim was there was an expectation of a few mm/s of speed. From where does such a remarkably slow speed come? Seems quite unlikely to me.
Wrong.
No, I am not wrong. If what you know is the speed (9 km/s), then you need a mass to get a temperature. Obviously, if you have the energy per particle instead, then you will have a temperature, but the article reports on an inference of 9 km/s, not 1 eV.
Exactly my point, read my post again. The claims in that article would allow us to determine that the dark matter particle mass is about that of a proton, so if they feel the consistency of the mass of dwarf galaxy haloes can tell us that, it would seem to be a result of vastly greater significance than saying that dark matter temperature estimates are "warming up." Why would they not instead report the bombshell discovery of the mass of the dark matter particle? That's what I'm puzzled about.
  • #64
Chronos said:
The temperature of dark matter remains an interesting issue in cosmology. The traditional 'cold' dark matter paradigm is under scrutiny as a consequence of new data and simulations. These discussions may be of interest http://www.nature.com/news/2006/060206/full/news060206-1.html.
First, thanks for the links.
I do have a problem with the article. For example, it states:
The team found that each galaxy seemed to contain the same amount of dark matter: roughly 30 million times the mass of the Sun. They say this is no coincidence. Instead, it represents the minimum amount of dark matter needed for a stable clump to hang together.
Presuming their math is right, the correct statement would be: The amount of DM found in these galaxies correspond to a DM temperature of 10K°C. What should not be implied is that 10K°C is a common temperature for DM - only that it is the temperature that formed these structures.
The reason that this is important is that a mass of DM does not readily transfer thermal energy to other DM masses. So gravitational structures will act as DM prisms - separating out DMs of different velocities not unlike flowing water can separate pebbles and sand into separate layers.
I imagine one DM layer, at 10K°C, visited our galaxy or was separated out by our galaxy's gravitation and then formed the clumping seen in this article.
  • #65
I do have a problem with the article. For example, it states:Presuming their math is right, the correct statement would be: The amount of DM found in these galaxies correspond to a DM temperature of 10K°C. What should not be implied is that 10K°C is a common temperature for DM - only that it is the temperature that formed these structures.
The "sorting" happens only above certain scale.
For example, at 10000K, and with DM particle mass of 2 GeV it has average thermal velocity of ~10km/s and would travel some 30 light years during each billion years (not taking into account that in the past their velocity was higher).
It means that all thermal inhomogeneities in DM below ~100 ly are erased: if you'd be able to "see" DM sky like we can today observe CMB sky, you would see some patches of sky having some DM temperature fluctuations, but you (and any other place) would receive streams of DM particles both from "cold spots" and from "warm spots", making temperature of DM particles flying through your neighborhood to be the average of sky "DM temperature".
  • #66
If DM does have weak interactions with ordinary matter I would anticipate DM could aggregate via temperature transfer to ordinary mattar. This could be a slow process, but, would suggest its temperature should tend to be lower in regions where it accretes more matter over long periods of time.
  • #67
Even purely gravitational interactions would lead to some transfer.
  • #68
haruspex said:
The normal matter in a galaxy, having shed energy as radiation, is thermodynamically cooler (i.e. less KE) than the dark matter zipping past it.
The thermodynamic term "temperature" is based on an equilibrium achieved by interactions (I. e. particle collisions). For dark matter such an interaction is unknown, therefor I think "temperature" is not defined for dark matter.
  • #69
Then ignore that term and just use my clarification "less KE".
  • #70
One thing to bear in mind is that the kinetic energy per particle is set by the virial theorem, so the more heat the baryonic gas loses to radiation, the higher its kinetic energy. But temperature only includes the energy of random motion, not the orbital energy associated with global angular momentum. So in a spiral galaxy, you have a lot of the kinetic energy in the baryons in a form that does not contribute to their temperature, and in that way, you can get the temperature to drop by radiating. That would not be possible in an elliptical galaxy, but if we are talking about spirals, then yes, the baryons that radiate will end up with less kinetic energy per particle than the dark matter-- except in the core bulge of the galaxy where there is not a propensity of angular momentum, and most of the energy does show up in the temperature. There the baryons should be hotter than the dark matter, since dark matter seems to be nearly isothermal, so has a kinetic energy per particle that is typical of the halo of the whole galaxy. Then the dark matter pressure that supports it against its own gravity, in a fluid picture (so with locally isotropic velocities), comes not from a temperature gradient, but rather from a density gradient.
  • Cosmology
  • Cosmology
