How would MWI explain delayed choice quantum eraser?
In summary: the two slit source of entangled photons would create an interference pattern because the photons that are sent to one slit and not the other are correlated.
Brendan D
How would MWI explain the delayed choice quantum eraser?
http://en.wikipedia.org/wiki/Delayed_choice_quantum_eraser#The_experiment_of_Kim_et_al._.282000.29
I don't see how this can be explained with MWI.
If the idler photon hits detector 1 or 2, an interference pattern can be seen on the screen.
If the idler photon hits detector 3 or 4, NO interference pattern is seen.
But the screen is hit BEFORE the idler photon hits the detector.
Can someone please explain this in detail according to the MWI explanation?
In the same way every experiment works in MWI: let the wave-function evolve.
You'll see that after the experiment is done (at the time where you check correlations between the detectors) all squared amplitudes match the observed frequencies (within statistical fluctuations of course). That is easier than collapse interpretations because you don't have to ask where which collapse happens.
If you find a detailed description of the experiment with collapses, remove the collapses and you get a detailed description in MWI. I don't have time now to write down everything, sorry, and I'm sure others did that before anyway.
Likes Derek Potter
The interference pattern is not seen either way, if by "seen" you mean that it can be observed before (or after, for that matter) the idler has been detected. An essential aspect of Kim's experiment is that there is no screen for the signal photons to strike and form an interference pattern. Instead there is a detector that is moved from one point to another, and at each point we see how many photons strike at the same time that an idler photon goes one way or another - the interference pattern only shows up in the after-the-fact correlation of idler photon detections and detections of the corresponding signal photon at various points.
The MWI explanation is that every entangled pair gives rise to two worlds, one in which the idler photon hits detectors one or two (another split) and the signal photon is more likely to end up in some places than others (with further multiplicity of worlds); and one in which the idler hits detectors three or four and the signal photon is more likely to end up in different places. Pick one of these worlds, then repeat for the next pair, and eventually you'll find yourself in a world in which a large number of detections have been made, all consistent with interference when the idler went one way and no interference when the idler went the other way.
Likes Derek Potter
Actually it's four worlds, |D1> |D2> |D3> and |D4> :biggrin: There are two which end up in separate "interference histories" and two which end up in "non-interference histories". The two "interference histories" show opposite peaks and troughs so they add up to a non-interference pattern. The two "non-interference histories" are extremely similar but are staggered by the slit spacing which is negligible. So as you say, a screen at D0 would definitely show a non-interference pattern.
It's important (I think) to realize that the interference patterns are not created by the two-slits! They, in fact, merely allow the laser to pump the down-converter at two small places. The down-conversions are independent events. The interference patterns are not normal interference at all, they are an example of "ghost" interference. What happens is this. The two paths effectively catch some photons and miss others. Thus they create a double aperture for the idler photons. The angle of the idler photon is mirrored by the signal photon, hence the (encrypted) interference patters are those of the double aperture, not of the original slits. I believe this accounts for why the interference patters are so crude compared to the nice clear stripes that a proper Young's Slit set-up can give.
This is incorrect. The pump is in-phase across the BBO so it behaves exactly like a two slit source of entangled photons even though it is not physically two slits. The aperture argument is wrong.
this helped me to understand, in a non-mathematical sense, what the delayed choice quantum data was showing , observation of an event entangles the observer and the observed.
from wikipedia
https://en.wikipedia.org/wiki/Many-worlds_interpretation
Everett's Ph.D. work provided such an alternative interpretation. Everett stated that for a composite system – for example a subject (the "observer" or measuring apparatus) observing an object (the "observed" system, such as a particle) – the statement that either the observer or the observed has a well-defined state is meaningless; in modern parlance, the observer and the observed have become entangled; we can only specify the state of one relative to the other, i.e., the state of the observer and the observed are correlated after the observation is made. This led Everett to derive from the unitary, deterministic dynamics alone (i.e., without assuming wavefunction collapse) the notion of a relativity of states.
Related to How would MWI explain delayed choice quantum eraser?
1. How does the Many-Worlds Interpretation (MWI) explain delayed choice quantum eraser?
The Many-Worlds Interpretation suggests that every possible outcome of a quantum event actually occurs in a different parallel universe. In the case of delayed choice quantum eraser, the act of measurement or observation determines which outcome is experienced in our universe, while the other outcomes are experienced in parallel universes.
2. What is the significance of delayed choice quantum eraser in the MWI?
Delayed choice quantum eraser experiments challenge traditional interpretations of quantum mechanics, such as the Copenhagen interpretation, by suggesting that the act of measurement or observation does not cause the collapse of the wave function. Instead, in the MWI, the wave function continues to evolve and all possible outcomes are realized in parallel universes.
3. How does MWI explain the behavior of quantum particles in delayed choice quantum eraser experiments?
In the MWI, quantum particles behave as waves until they are observed or measured. This means that they can exist in multiple states simultaneously, until the act of measurement collapses the wave function and determines the particle's state in our universe.
4. Can MWI be tested or proven through delayed choice quantum eraser experiments?
While delayed choice quantum eraser experiments support the ideas of MWI, they cannot definitively prove or disprove it. MWI is a philosophical interpretation of quantum mechanics and cannot be directly tested. However, the consistent results of these experiments provide evidence for the validity of MWI.
5. What are the implications of MWI for our understanding of reality?
MWI suggests that our reality is just one of many parallel universes, each with its own set of events and outcomes. This challenges our traditional understanding of causality and suggests that there are infinite possibilities and versions of ourselves in the multiverse. MWI also raises questions about free will and the nature of consciousness.
