MHB HSO4^-1 as Arrhenius & Bronsted-Lowry Acid/Base
  • Thread starter Thread starter markosheehan
    Arrhenius
HSO4^-1 acts as an Arrhenius acid by dissociating in water to produce hydrogen ions, represented by the equation HSO4^- + H2O → SO4^2- + H3O+. As a Brønsted-Lowry base, it accepts a proton, shown by the equation HSO4^- + H+ → H2SO4. Both behaviors illustrate the dual role of HSO4^-1 in acid-base chemistry. This demonstrates its versatility in different acid-base theories. Understanding these reactions is essential for grasping the properties of HSO4^-1 in aqueous solutions.
markosheehan
write down 2 equations to show how the HSO4^-1 ion can behave as a arrhenius acid and bronsted lowry base
i know if its a arrhenius acid it dissociates in water to produce hydrogen ions
so HSO4^-1 +h20 goes to SO4^-2 and the hydronium ion. is this right? i don't know how to show if its a bronsted lowry base
Mathematics news on Phys.org
Hi markosheehan,
Behavior as an Arrhenius acid means it donates an $H^+$ ion to $H_2O$.
So indeed:
$$HSO_4^{-}(aq) \to SO_4^{2-}(aq) + H^+(aq)$$
Behavior as a Brønsted–Lowry base means it accepts an $H^+$ ion.
So:
$$HSO_4^{-} + H^+ \to H_2SO_4$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
