Hubble Constant, Dark Energy and the Expanding Universe
In summary, the Hubble Constant quantifies the rate of the universe's expansion, indicating that galaxies are moving away from us at speeds proportional to their distances. This expansion, first observed by Edwin Hubble, suggests that the universe is not static but dynamic. Dark energy, a mysterious force comprising about 70% of the universe's energy density, is thought to drive this accelerated expansion. Understanding the Hubble Constant and dark energy is crucial for cosmology, as it helps scientists explore the universe's fate and the fundamental nature of space and time.
PhanthomJay
530
TL;DR Summary
Recent info from Hubble suggests an Increasing Hubble constant (Source: NASA) that was originally thought to be decreasing, especially since Dark Energy assists in decreasing the expansion due to its own accelerating expansion properties that are making the universe less dense. Please explain this paradox.
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
Space news on Phys.org
I think about it as follows:
The Hubble parameter ##H=\frac {\dot a} a##, where ##a## is the scale factor. To see how it changes in time, I take ##\dot H=\frac {\ddot a a-\dot a \dot a}{a^2}##.
If the expansion is constant, ##\ddot a =0##, then ##\dot H \lt 0##, i.e., the Hubble parameter decreases.
If the expansion accelerates, ##\ddot a \gt 0##, then the Hubble constant increases if ##\ddot a a \gt {\dot a}^2## and decreases otherwise. So, the outcome depends on the values of ##a, \dot a,## and ##\ddot a## at the moment.
Likes PhanthomJay, PeroK and Orodruin
This is a common confusion. The bottom line is that when we say accelerating expansion we mean ##\ddot a > 0##, which means that ##\dot a## increases, whereas the Hubble parameter is ##\dot a/ a##. Even if ##\dot a## increases, ##H## might not as covered in the previous post. In fact, in a dark energy dominated universe, ##H## is constant.
Likes PeterDonis and PhanthomJay
FAQ: Hubble Constant, Dark Energy and the Expanding Universe
What is the Hubble Constant?
The Hubble Constant is the rate at which the universe is expanding. It is denoted by the symbol H₀ and is typically measured in kilometers per second per megaparsec (km/s/Mpc). The value of the Hubble Constant helps astronomers determine the size, age, and ultimate fate of the universe.
What is Dark Energy?
Dark Energy is a mysterious form of energy that makes up about 68% of the universe and is thought to be responsible for the accelerated expansion of the universe. Unlike dark matter, which has gravitational effects, dark energy appears to have a repulsive effect, driving galaxies apart at an increasing rate.
How do we measure the Hubble Constant?
The Hubble Constant is measured by observing distant galaxies and determining their redshifts, which indicate how fast they are moving away from us. By comparing these redshifts with the distances to these galaxies, astronomers can calculate the rate of expansion of the universe. Various methods, including the use of Cepheid variable stars and Type Ia supernovae as standard candles, are employed to estimate these distances.
Why is there a discrepancy in the Hubble Constant measurements?
There is currently a discrepancy between the Hubble Constant values obtained from observations of the early universe, such as the Cosmic Microwave Background (CMB) measurements by the Planck satellite, and those obtained from observations of the local universe, such as supernovae and Cepheid variables. This discrepancy, known as the "Hubble tension," suggests that there may be new physics or unaccounted-for factors influencing our measurements.
What is the significance of the expanding universe?
The expanding universe is a fundamental concept in cosmology that implies the universe has been growing since the Big Bang. This expansion affects our understanding of the universe’s origin, structure, and ultimate fate. It also provides evidence for the Big Bang theory and helps explain the distribution and movement of galaxies. The discovery of the accelerating expansion due to dark energy has profound implications for the future of the universe, suggesting it may continue to expand indefinitely.
