- #36
ohwilleke
- 1,415
Mordred said:Well I for one have always hated the "new physics required " trend you see in a large number of different studies where some contention shows up. Seems to be a very common declaration often used particularly but not restricted to pop media.
Mordred said:Typically what I've seen in the last few decades of various studies where some contention shows up the problem often gets resolved via some calibration fine tuning or other related systematic error margin etc.
I hear you, and agree with you strongly in the area of high energy physics and in describing highly relativistic systems like black holes and white dwarf-black hole binary systems.Mordred said:Our models are extremely successful and robust with huge supportive bodies of evidence that are extremely interconnected among numerous related physics theories. Knowing this I typically approach these findings with the frame of mind that new physics isn't usually the answer
However that's just me
In the case of cosmology, while there is something to be said for not leaping off to new physics without trying to give existing models a try, it is also true that the LambdaCDM model is not nearly as complete as the Standard Model of Particle Physics, for example.
The CDM part of the LambdaCDM model is basically a placeholder with a quite general description of dark matter's properties, but a lot of the specifics not worked out.
Also, while it would be one thing if the Hubble tension was the only issue with the LambdaCDM model, and indeed, it is still, barely, possible that the Hubble tension could be resolved with improved measurements, the LambdaCDM model has lots and lots and lots of independently measured tensions with astronomy observations, i.e. dozens of them (something that has been explored in some detail and length in other PF threads).
The unmodified LambdaCDM model remains the paradigm mostly because it is easy to work with and has few parameters (just six in the most basic version), and because no consensus has emerged around any one alternative to it.
