Hubble's law and conservation of energy
In summary, two bodies moving in circular orbits around each other will experience a force of attraction due to gravity, which is balanced by their centrifugal force. However, in an expanding universe, this force of attraction may be counteracted by the expansion itself, resulting in a stable orbit even at large distances. This is due to the fact that the expansion of the universe causes a constant acceleration, which can balance out the gravitational force between the objects.
  • #36
Hi @George Jones:
I appreciate your effort to help me resolve my confusion regarding putting the Einstein static universe equation into the Friedmann form. However, the items in your post are not what confuses me.
Einstein's model without a cosmological constant involved assumptions that the density of matter exceeded the critical density, and therefore
Ωr = ΩΛ = 0​
Ωm > 1, and​
Ωk = 1 - Ωm < 0.​
This produces an expanding universe that reaches a maximum radius of curvature, and then the universe contracts. That is, for this model, the stationary universe is not stable. What I am unable to see is how the addition of the cosmological constant creates stability. That is, given
Ωr = 0,​
Ωm > 1,​
Ωk< 0​
and
ΩΛ = 1 - Ωm - Ωk ≠ 0,​
I see no way for this form of the Friedman equation model to be static and stable. Therefore, I am unable to undestand why Einstein added a cosmological constant to his 1917 model.
Regards,
Buzz
Space news on Phys.org
  • #37
@Buzz Bloom In Einstein's static universe matter density and ##\Lambda## cancel each other (see the 2. Friedmann equation) and thus the second derivative of the scalefactor is zero (which means static).
Likes Buzz Bloom and George Jones
  • #38
This can't be seen directly from this equation; the time-derivative of this equation also needs to be considered. Einstein concocted a situation in which the time-derivative (rate of change) of each individual term is zero.
The second derivative equal to zero implies that the first derivative is constant. Then, a condition needs to be satisfied that forces this constant first derivative to be zero.
1) I don't know if this is legible.
2) if it is legible, I don't know if this is understandable.
3) ##\Lambda## has been treated as constant of integration.
  • #39
I'm not sure I understand what you mean.
##\ddot{a}=0## yields ##\Lambda_{stat}=4{\pi}G\rho##; [##c=1##]
I agree this "implies that the first derivative is constant." Would you let me know your concern?
EDIT ah I see, yes your script is legible.
  • #40
timmdeeg said:
In Einstein's static universe matter density and Λ cancel each other (see the 2. Friedmann equation) and thus the second derivative of the scalefactor is zero (which means static).
Hi timdeeg:
Thank you very much for clearing up much of my confusion.
I think by Friedmann #2 equation you are referring to
What puzzled me is how to put this equation onto the Friedmann form
I also do not know how to put the pressure term into this form.
I see that in the first equation above that the curvature term is missing, and I had (mistakenly?) thought Einstein's solution with Λ also had assumed a finite hyperspherical universe. Is it not possible that Einstein intended somethink like the following put into a form involving the second derivative of a?
I think if that I differentiate the second or third equation I might be able to put these results into a form like the first.
ADDED:
I did differentiate the second equation, and I got a cubic equation in R (the radius of curvature) which should result in a solution value for R corresponding to a finite stable stationary universe. I will post this result at a later time. (There should also be solutions for a flat infinite universe and for a non-flat infinite universe. I am not sure that the solutions for the infinite cases are meaningful.)
Thanks again for the help.
Regards,
Buzz
  • #41
Hi George:
Thanks for trying to help me, but I think it does appear to be unreadable. I am sympathetic to not liking the posting of a lot of equations. I have from time to time used LaTeX a bit, and I still find it very awkward to use.
I will try to copy what I think I am reading onto a paper I can more easily read. Then I can decide if I can understand it.
Regards,
Buzz
  • #42
This is because the two equations are independent.
Einstein's static universe does have non-zero positive spatial curvature.
  • #43
Question in post #29 was whether in frame of reference of any location there is some force that causes objects to move away. For example is there any force in rope between 2 very distant bodies, that have masses ##m_1## and ##m_2## and charges ##q_1=\sqrt{\frac{m_1*m_1*k_G}{k_E}}## ; ##q_2=\sqrt{\frac{m_1*m_1*k_G}{k_E}}##? speed between bodies at time 0 is 0 (##v(0)=0##). My intuition is that there would be force in case of accelerating expansion.
Bandersnatch said:
I don't understand the question.
As I understand the expansion means that in every location objects tend to move father away with speed on average ##d*H_0##. d is distance to object.
My question in post #31 was: If universe would not be expanding and Earth would be in a special location from which other objects tend to move away with speed ##d*H_0## - would the force measuremetns with ropes attached to distant objects give the same result?
  • #44
My pleasure, seldom enough that an amateur can contribute. :smile:
View attachment 245637.
This equation with ##H=0## (universe static) and ##\Lambda_{stat}=4{\pi}G\rho## leads to ##k/a^2=4{\pi}G\rho##
  • #45
timmdeeg said:
This equation with H=0 (universe static) and
Λstat=4πGρ​
leads to
k/a2=4πGρ​
Hi timmdeeg:
I note that you use "a" where I used "R".
I get a different solution assuming H=0. I also use k=1.
If the static universe has radius of curvature R, and mass M corresponding to mass density ρ,
ρ = M /(2π2R3) .​
Therefore
(4/3)GM/πc2R3 - 1/R2 + Λc2/3 = 0 .​
Multiplying by 3R3 we get
4GM/πc2 - 3R + Λc2R3 = 0.​
However, this equation establishes only that the universe is stationary. For it to also have the acceleration zero (d2R/dt2=0), then differentiating the equation above gives an additional equation.
ADDED
3(dR/dt) = 3Λc2R2(dR/dt), yielding​
Λ = 1 / c2R2.​
Combining this with the undifferentiated equation yields
4GM/πc2 - 3R + R = 0.​
Simplifying
R = 2GM/πc2.​
Simplifying
Λ = (1/c2) (π2c4/4G2M2)​
= π2c2/4G2M2.​
Regards,
Buzz
I think I have now fixed all the errors, but experience has taught me to not have a high confidence I am correct.
ADDED June 26
I have now fixed 2 another errors.
The first correction is about the 3D volume as the containing boundary of a 4D hypersphere. It is
V = 2π2/R3.​
Reference:
The second fix is corecting that I misused the word "stable".
  • #46
Buzz Bloom said:
However, this equation establishes only that the universe is stationary. For it to also be stable
I have not tried to analyze what you have, but it has been known for almost a century (since at least 1930) that he Einstein static universe is unstable in the following sense.
Consider an Einstein static universe whose cosmological scale factor is ##a_s##. Hit the universe with a stick (nicking a phrase from Robert Geroch) such that its scale factor becomes slightly larger than ##a_s##. Then, the scale factor, over time, will grow in an unbounded way. Hit the universe with a stick such that its scale factor becomes slightly smaller than ##a_s##. Then, the scale factor, over time, will decrease to zero.
  • #47
ρ = 2 M /(π2R3) .​
Therefore
(16/3)GM/πc2R3 - 1/R2 + Λc2/3 = 0 .​
Can you show how you derive the first equation? Why do you intend to express ##\rho## by ##M## and ##R##?​
I think the requirement that ##k## is positive and ##(\rho+3p)=0## is much simpler.​
  • #48
timmdeeg said:
Can you show how you derive the first equation? Why do you intend to express ρ by M and R? I think the requirement that k is positive and (ρ+3p)=0 is much easier.
Hi timmdeeg:
I am not sure what equation you are referring to by "the first equation", or what post it was in. Since you are asking about my deriving it, I am guessing it was
ρ = 2 M /(π2R3) .​
This is derived from
ρ = M/V, and​
V=2π2R3.​
I just noticed that I made an error in my post #45 which I have just corrected
The formula for volume V is from
I replace ρ with its formula using M and R because this makes the time derivative less complicated. Since R and Λ are the parameters for which the values are to be calculated that correspond to the first and second derivatives being zero, I felt it easier to have only R be a function of time.
I do not understand why you think (ρ+3p)=0 is related to the problem of finding a universe model which is not expanding nor contracting, and also has the acceleration (d2R/dR2)=0.
I did make k=+1, which made the middle term on the RHS: -1/R2. (ρ+3p)=0 has to be wrong since the Einstein universe model has mass, ρ>0, and Einstein also assumed matter was just dust so the pressure p=0. Someone educated me about this recently in another post, but I am not able to find it right now.
Regards,
Buzz
  • #49
Why? In Einstein's static universe ##R## isn't a function of time.
Yes, the pressure of dust is negligible. What counts is the negative pressure of ##\Lambda##. Finally one obtains ##\rho_M-2\rho_{\Lambda}=0##.
  • #50
timmdeeg said:
Why? In Einstein's static universe R isn't a function of time.
Yes, the pressure of dust is negligible. What counts is the negative pressure of Λ. Finally one obtains ρM−2ρΛ=0.
Hi timmdeeg:
I used "R" instead of "a" because R varies the same way that a varies, except while a=1 corresponds to now, we would need to use R=R0 since the value of R now is not 1. We could also define R=R0 to be the sought after value of R that satisfies the two equation I have at the end of the next paragraph.
Einstein's static universe is a special case of a finite universe with two parameters: a constant mass M (non-varying with respect to R and therefore also t) and a constant Λ. If ρ remains in the equation to be differentiated, then it also varies with R and t creating some extra complexity. The special case is one in which
dR/dt=0, and​
d2R/dt2=0.​
I do not understand what form of the Einstein/Friedmann equation you started with, and how you get from that to
ρM−2ρΛ=0.​
Th Einstein static model also includes a radius of curvature term, which is -1/R2 in the equation. This is for an unbounded finite universe with with the geometry of a 3D boundary to a 4D hypersphere. Without both the -1/R2 term and the Λ term, there is no solution satisfying both
dR/dt=0, and​
d2R/dt2=0.​
It is also possible to have a model with an M term (or a ρ term) and a -1/R2 term without a Λ term. This model's equation can also be solved for a value of R such that
dR/dt=0,​
but it cannot also satisfy
d2R/dt2=0.​
Regards,
Buzz
  • #51
Hi @George Jones:
In your post #38 I think I now understand everything you are doing except for two topics.
(1) The tensor equation. Although in my youth I could understand a bit about tensor calculus, I have forgotten all of what I once knew about it.
(2) I do not understand what the ε symbol represents and how the ε relates to the Friedmann equation you included, nor the equation with ε_dot (marked "unchanged"), nor other equations involving ε.
ADDED
I now understand that you use ε rather than ρ for the mass density.
Regards,
Buzz
  • #52
ρM−2ρΛ=0.​
From the acceleration equation. With ##p_M=0## then ##\rho+3p## can be rewritten as ##\rho_M+\rho_\Lambda+3p_\Lambda=\rho_M-2\rho_\Lambda## thereby considering the negative pressure of state ##p_V=-\rho_V##. Note ##c=1##.
  • #53
Hi timmdeeg:
Is the following what you mean by the acceleration equation?
ADDED
I now am guessing you mean the equation you labeled "acceleration" in your handwritten text. Below I use the prime ' instead of the dot.
ε' = (-4πG/2c2)(ε+3P) + Λ/3​
Is this what you have in mind?
Also, where did you get the Friedmann equation you used? Can you cite a reference?
Also, your differentiating the Friedmann equation doesn't look right to me.
You also seem to be assuming that P and Λ are related. Einstein assumed P=0, and Λ is an independent constant.
Regards,
Buzz
  • #54
No the 2. Friedmann equation which is named acceleration equation sometimes. I guess this clarifies your other questions.
  • #55
I have not set ##c = 1##. ##\varepsilon## is energy density, which is related to mass density ##\rho## by ##\varepsilon = \rho c^2##.
  • #56
Hi George:
My mistake was using the word "stable" in my earlier posts when I should have used "metastable".
Metastable
Describes a system which appears to be stable, but which can undergo a rapid change if disturbed.​
Quoted by
from
Dictionary of Unfamiliar Words by Diagram Group Copyright © 2008 by Diagram Visual Information Limited.​
Regards,
Buzz
  • #57
Buzz Bloom said:
Hi George:
Metastable requires the system be able to remain in that configuration for an extended period of time. I don't think that universe model qualifies, as any inhomogeneities will grow pretty rapidly.
  • #58
Perhaps @metastable would agree. I think "unstable equilibrium" fits better to Einstein's static universe.
  • #59
Hi kimbyd and timmdeeg:
I do not want to struggle about vocabulary. I chose "metastable" because I could not find any other word that seemed to be suitable.
To respond clearly I need some notation. I use the apostrophe, (whatever') to represetnt dwhatever/dt. (Using the dot is too awkward for me.) With respect to the equation
let
R0 = R(t0)​
be the value of R for which
R'(t0)=R''(t0)=0.​
It will also be useful to let
r(t)=R(t)-R0.​
The assumptions of the model assumes it is homogeneous, that is, no inhomogeneities. The reason it does not qualify for "stable" is that the sign of R'(t0+ε) and R''(t0+ε) will be the same as the sign of (R0+ε). I believe this condition regarding R'(t0+ε) and R''(t0+ε) is true, but to satisfy my curiosity I am currently working on the math to prove it is true. So far I have made many errors, and found them, and I think properly corrected them.
ADDED July 1
And found more errors...
You seem to be correct about what "unstable equilibrium" means.
Comparing the two definitions, this seems to me to be a synonym of "metastable". There is a subtle difference. The assumptions of the model makes it difficult for something to cause a movement away from metastability.
Regards,
Buzz
  • #60
It doesn't really matter that the model is homogeneous, because our universe manifestly is not. It's very obvious that if this model were to describe anything real, it would need to allow for inhomogeneities. The reason I bring this up is because if you don't have any inhomogeneities, that model can be balanced on the head of a pin, so to speak, such that it remains in the unstable equilibrium for an excessively long period of time.
But if you do have inhomogeneities, then maintaining that balance becomes fundamentally impossible. All you need to break the system is for a baseball to move a little to the left (or whatever direction).
  • #61
https://arxiv.org/pdf/1203.4513.pdf
3 Study of stability
Figure 1 ... Notice that the equilibrium at ##R = R_E## is an unstable one. Any small perturbation at ##R_E## makes either the universe to collapse or diverge to R → ∞.
I'm not sure if the question whether or not there are inhomogeneities matters at all.
@Buzz Bloom You might be interested to see how the radius of curvature of Einstein’s static universe ##R## depends on ##\rho##, (10) .
  • #62
Note the "any small perturbation" part. Those are inhomogeneities.
  • #63
timmdeeg said:
@Buzz Bloom You might be interested to see how the radius of curvature of Einstein’s static universe R depends on ρ, (10) .
Hi timmdeeg:
I don't know what this means. I did my own calculation of the relationship between R0 and ρ, except I calculated
R0 = 2GM/πc2, where
M=ρV, where
V= 2π2R03 is volume.
Post #45​
What does "(10)" mean?
ADDED JULY 1
I found equation (10).
Solving for ρ0G,
ρ0G = c2/4πR2.​
I also found a definition of ρ0,
This seems to be peculiar for a finite closed universe, making ρ0 equal to a fraction of the mass M=ρV I used.
ρ0 = M/2π2
I only scanned the article, and it seems that the intent is to be more general than Einstein's finite closed model. In a flat or hyperbolic model, the concept of total mass M would not be defined.
Also, the article's equation (2) is different than the one I used for a finite universe with cosmological constant. I need to do some research about the differences.
Thanks for the citation.
Regards,
Buzz
  • #64
But according to the abstract the article is based on the ideal fluid model, whereas in #60 you talk about the real universe:
It seems the universe isn‘t stable even in the ideal case due to perturbations. I wonder if it is less stable in the real case. Or is this consideration flawed insofar as in the real case homogeneity can be assumed if the scales are large enough und thus globally?
  • #65
Again, perturbations are another word for inhomogeneities. Specifically, they're a mechanism to mathematically describe inhomogeneities.
And as long as you have any matter, some level of inhomogeneity is a fundamental requirement. The only way to get away from inhomogeneities entirely is to have every quantum field in its ground state, which means Minkowski or de Sitter space.
Thus whenever you hear the universe described as homogeneous, it must always be considered an approximation.
  • #66
Thanks for your answer. I’m not yet sure if I understand you correctly though.
In #64 you seem to distinguish two cases:
Real universe, inhomogeneities, “ balance becomes fundamentally impossible”.
No inhomogeneities (what I understand to mean the perfect fluid model), “model can be balanced”.
What kind of model do you refer to? As I understand it perturbations are there regardless the model but then no model can be balanced.
  • #67
My point is that if the universe is perfectly homogeneous, it's technically possible to allow it to sit in the unstable static condition where the cosmological constant perfectly balances matter. It requires infinite fine tuning, but it's technically possible.
But a real universe can't ever be perfectly homogeneous, even in principle, as long as there is some matter (or any quantum field not in its ground state). So even if you set it up so that it is balanced at one point in time, stuff is moving around. All you need is a little motion in one direction and the universe will collapse or start expanding.
  • #68
Do you say that “infinite fine tuning” implies the absence of “any small perturbation” (as mentioned in the article linked in #60)?
  • #69
Of course it does. "Infinite fine tuning" means the density of matter is exactly the same, to infinite precision, everywhere in the universe (and its value is exactly the value needed to balance the effect of the cosmological constant). That means there can't be any perturbations, no matter how small.
  • #70
So it isn’t correct to think of the perfect fluid model as being infinitely fine tuned, right?
