I Hugo Duminil-Copin, permanent professor at IHES, 2022 Fields Medalist
  • I
  • Thread starter Thread starter Astronuc
    Fields Professor
Hugo Duminil-Copin, a permanent professor at the Institut des Hautes Études Scientifiques (IHES) since 2016, was awarded the Fields Medal in 2022 for his contributions to mathematics. His work focuses on statistical physics and phase transitions in mathematical models. Alongside Duminil-Copin, Maryna Viazovska also received a Fields Medal, making her the second woman to achieve this honor. The discussion highlights the significance of these awards in recognizing groundbreaking research in mathematics. The achievements of these mathematicians underscore the importance of their contributions to the field.
Mathematics news on Phys.org
jedishrfu said:
Here are the other winners as well as Prof Hugo Duminil-Copin:
https://www.mathunion.org/imu-awards/fields-medal/fields-medals-2022
Maryna Viazovska, who works on the geometry of spheres and is one of four winners of the coveted prize this year, becomes the second woman to win a Fields medal.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
