Hydraulic Pump/Motor: Can it Work as a Motor?
  • Thread starter Thread starter 1nv3n73r
    Hydraulic
A hydraulic pump can theoretically function as a hydraulic motor due to their interchangeable concepts, but most pumps cannot be backdriven, limiting their use as motors. Hydraulic pumps are typically designed for unidirectional flow and have specific pressure requirements, while hydraulic motors can operate bi-directionally and often include a drain connection. Efficiency for both pumps and motors can reach up to 90%, but using a pump to drive a motor results in compounded inefficiencies, leading to a total efficiency of around 81%. Additionally, the design differences between pumps and motors necessitate careful consideration for practical applications. Understanding these distinctions is crucial for anyone looking to implement a hydro-static transmission system effectively.
1nv3n73r
hey people. literally just joined, hehehe
my question is, can a hydraulic pump be used as a hydraulic motor. i have an idea and want to have it operating using hydraulics rather than having shafts and gearboxes to transfere to work.
any comments welcome, good or bad, but i prefere good...hehehe
From Wikipedia:
Conceptually, a hydraulic motor should be interchangeable with a hydraulic pump because it performs the opposite function - similar to the way a DC electric motor is theoretically interchangeable with a DC electrical generator. However, most hydraulic pumps cannot be used as hydraulic motors because they cannot be backdriven. Also, a hydraulic motor is usually designed for working pressure at both sides of the motor.
Thanks Jack action.
There is information there that I didn't know about.
What you are describing is a hydro-static transmission. The pump and motor can each be designed to be pump/motors, but they aren't necessarily that way, as jack action said.
Conceptually simple, but there are many traps for the beginner. Pumps will often have a big inlet because only atmospheric pressure is available to push oil into the pump chamber, it can have a smaller outlet.
Pumps are usually designed to rotate in one particular direction. A hydraulic pump is designed to have a low and a high pressure side with seals to prevent it sucking air on the inlet side or weeping oil on the high pressure side.
A hydraulic motor may be designed for bi-directional operation. It can be operated with positive pressure on both ports. Bidirectional motors will have a third connection to drain fluid to the reservoir tank that leaks past the internal seals.
Hydraulic motors and pumps might get to 90% efficiency. A pump driving a motor will therefore have 90% * 90% = 81% efficiency. You will need to pay for that 19% inefficiency, you will also need an oil cooler to remove the 19% waste heat. A manual change gearbox will be closer to 98% efficient.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
