Hydrodynamics/Pressure Problem
  • Thread starter Thread starter tak08810
The discussion revolves around a hydrodynamics problem involving water flow through a pipe with varying diameters and pressure measurements. The key equations referenced include Bernoulli's Equation and the continuity equation, which relate pressure, velocity, and height in fluid dynamics. The user initially calculated the velocity and pressure but found inconsistencies in the results, particularly regarding the height of the fluid in vertical pipes. They received guidance to consider the conservation of energy in their calculations and were directed to research the venturi tube concept for further understanding. Ultimately, the user resolved the problem with the provided insights.
tak08810
Water flows through the pipe, as shown in the figure below and exits to the atmosphere at the right end of section C.
The diameter of the pipe is 2.04 cm at A, 1.02 cm at B, and 0.850 cm at C. The gauge pressure in the pipe at the center of section A is 1.25 atm and the flow rate is 0.812 L/s. The vertical pipes are open to the air. Find the level (above the flow midline as shown) of the liquid-air interfaces in the two vertical pipes. Assume laminar nonviscous flow.
P = P0 + dgh (d= density) (?)
Bernoulli's Equation: P + 1/2pv^2 = constant
A1V1 = A2V2
First, I converted L/s to m/s. I go the velocity at the beginning of the pipe to be 2.48 m/s. Then I plugged it into the equation A1V1=A2V2=, or rather the fact that the diameter decreases by half means the velocity is quadrupled (since area is the square of the radius). Then plugging into the Bernoulli's Equation, i foudn the atmospheric pressure at the second vertical tunnel to be 12.04 atm. Then I put the values into the first equation to determine height of the fluid. That did not give me the answer, not to mention the values seemed far too high. Also, where does the diameter of C fit in? Please help! Thank you.
bump!
It may help if you use the Bernoulli equation that deals with conservation of energy
<br /> U= .5\rho v^2 + \rho gz + P<br />
This is a well known device called a venturi tube, so if you get stuck some more you can look that up.
I figured it out. Thanks though!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
