Hydroelectric powerstation with Asynchronous or synchronous generator
In summary: In order to decrease the voltage, more capacitor must be switched in. This type of generator may not be suitable for islanded mode operation. A synchronous generator will be a generator if it's spun > synchronous speed and it will be a motor if it's spun < synchronous speed. The speed-torque curve is symmetrical about synchronous speed.A wound rotor generator will be a generator if the rotor is spinning and there is an external voltage present. In order to operate in island mode, the generator must have a capacitor bank connected. Induction machines are also generators, but they will not be operating in synchrony with the power grid. They will be operating at a different speed, which must be taken
vampslayer
24
Let's say we have small hydropower plant which can operate in on-grid and in islanded mode too.
I understand a principles of frequency and active power control in a case we have synchronous generator, but what would be diff in a case of Asynchronous generator? How do we controll frequency in a case of A.G?
Since the Asynchronous generator needs reactive power to work, how can hydropower plant with Asynchronous generator work in ISLANDED mode then?
It can't, with the most common type of asynchronous generator, the plain old induction machine.. You must provide such a generator with exciting power to its stator.
Remember that an induction machine will be a generator if it's spun > synchronous speed
With no external voltage there's nothing for it to be synchronous with, or asynchronous either.
Perhaps it'd be better to call the two types of machine by their other names, "Wound Rotor" and Induction".
Hello Vamp- and sorry Jim... I must disagree with "It can't", this is used in wind generation frequently, and known as doubly fed induction generator. ( https://en.wikipedia.org/wiki/Doubly_fed_electric_machine )
However in islanded mode - this would take some tricks in the controls - but should be possible, I am thinking a rather large DC Capacitance in the converter.
Of course Asynchronus can also mean a PM Generator - just not in sync, that can be handled by a power converter. ( Rectify then Inverter to pure AC) - for a smaller power system, this would be the way to go due to efficiency. Up to 100KW or so this is often referred to as micro-hydro.
No disagreement here. I should have said 'it's not nearly so straightforward as with a synchronous machine'
Here's a link to a pretty good paper I stumbled across a while back
https://www.calvin.edu/~pribeiro/courses/Power%20Systems%20Interim/wind-generator-types.pdf
with generic generator descriptions...
Thx both of you
The below is related to a squirrel-cage IM in island mode:
If you draw the torque-speed curve for motor and generator operation, you will notice how the slip changes according to loading (active power). This gives a direct correlation between the electrical frequency and the rotor speed.
As for reactive power, which is closely related to voltage, is also depends on the active and reactive loading of the generator. A fixed capacitor bank connected to the terminals of the machine provides reactive power in relation to the voltage squared. Increasing the reactive power loading decreases the voltage, which could have a severe effect on the system. In order to increase the voltage, more capacitor must be switched in. A SVC (static VAR compensator) or STATCOM could control the reactive power in a "step-less" manner.
Small portable generators may have a simple IM with fixed capacitor bank, and voltage is in such system may vary to a large extent.
Related to Hydroelectric powerstation with Asynchronous or synchronous generator
1. How does a hydroelectric power station with an asynchronous or synchronous generator work?
A hydroelectric power station uses the force of falling water to turn a turbine, which is connected to a generator. The generator converts the rotational energy from the turbine into electrical energy. In an asynchronous generator, the turbine and generator are not directly connected and the generator's speed is controlled by an electronic converter. In a synchronous generator, the turbine and generator are connected and the generator's speed is synchronized with the turbine's rotation.
2. What is the difference between an asynchronous and synchronous generator in a hydroelectric power station?
The main difference is in the way they are connected to the turbine. Asynchronous generators use an electronic converter to control the speed, while synchronous generators are directly connected to the turbine and their speed is synchronized with the turbine's rotation. This can affect the efficiency and control of the power station.
3. What are the advantages of using an asynchronous generator in a hydroelectric power station?
Asynchronous generators allow for more flexible control of the power station, as the speed can be adjusted independently from the turbine's rotation. This can be beneficial in situations where the water flow varies. Asynchronous generators are also more durable and require less maintenance compared to synchronous generators.
4. What are the disadvantages of using a synchronous generator in a hydroelectric power station?
One major disadvantage of synchronous generators is that they are more sensitive to variations in the water flow and require a constant speed to maintain synchronization with the turbine's rotation. This can lead to fluctuations in the power output and may require additional control systems. Synchronous generators also tend to be more expensive and require more maintenance compared to asynchronous generators.
5. How does the choice between an asynchronous or synchronous generator affect the overall efficiency of a hydroelectric power station?
The efficiency of a hydroelectric power station depends on various factors, including the type of generator used. In general, asynchronous generators have a higher efficiency due to their simpler design and less maintenance requirements. However, the efficiency also depends on the specific design and operating conditions of the power station. Both types of generators have their own advantages and disadvantages, and the most suitable choice will depend on the specific needs and conditions of the power station.
  • Electrical Engineering
