Hydrogen anions - how do they form?
In summary: If the two electrons are on the opposite sides of the proton at a given time, is the electron-electron repulsive force greater than, or less than the electron-proton attractive force? In general, the electron-electron repulsive force is greater than the electron-proton attractive force.
sciFax
TL;DR Summary
I have only very recently been made aware of the existence of ##H^-## hydrogen anions, something which I had previously thought impossible. So how is this possible?
Having read a few Wiki articles on and around the subject, I am now somewhat aware of the means by which these ##H^-## anions acquire the extra electrons "donated" by e.g. ionized alkali atoms in stellar atmospheres, and the means by which they provide opacity.
What I don't understand is how it is possible for two negatively charged electrons to exist in stable "orbits/shells" around the single positively charged proton in the nucleus.
Answer A - the two electron-proton attractions overcome the single electron-electron repulsion.
Answer B - just as you gain 13.6 eV when one electron falls into the potential generated by a proton, you gain 0.75 when a second electron falls in.
Likes andrew s 1905
@Vanadium 50 Your answer A is interesting, and will certainly lead me to look further into this. I still find it surprising that the positive charge of the central proton is not completely "balanced out" by the initial single electron of the neutral hydrogen atom. Would it be possible to have, say, three electrons in a hydrogen atom, or are two the maximum number permissible by the 1n electron shell?
Your answer B gives me further context in which to understand numbers seen in e.g. the Wiki hydrogen anion page where they mention an electron affinity of ~0.75 eV and an overall ground state energy of ~ -14.36 eV, being evidently the sum of 13.6 and 0.75 eV.
Thanks for your input!
What does "possible" mean? It's possible to keep adding electrons until it becomes energetically unfavorable to do so, but I'm pretty sure that this always happens by N = 3. So it's possible to happen, but it just doesn't.
Well, there's quite possibly a definite quantum mechanical or mathematical definition of the word "possible" in such a context, and speaking as a layman, I am definitely, and unfortunately, unaware of such a definition.
So, as a layman, I would probably reformulate my question in something like these terms: "do the rules of QM admit of such an eventuality that two or even more electrons could become attached to a proton/hydrogen nucleus", or "is there a solution to the schrödinger equation for the hydrogen atom which allows for the existence of, say, a hydrogen ##H^-## anion". Or other probably/possibly equally vague formulations expected to be burbled by a layman...
I don't dare question @Vanadium 50, but shouldn't we be saying that for a given electron, the electron-proton attraction overcomes the electron-electron repulsion? My simple mind doesn't understand what it means to say the two electron-proton attractions overcome the electron-electron repulsion, when the interactions are between different pairs of particles.
@etotheipi I think I understand in a non-technical what @Vanadium 50 's saying - I quite possibly have this wrong, but it's like the electrons are not actually in shells as such, but form "probabilistic clouds" around the proton, and can form localized pairs where each electron interacts with the proton, but don't "see" each other quite so well from the positions they may take in their own "cloud".
I don't have my Lego set with me right now, but I'm sure I could build something along these lines. Or maybe mud-pies would be more appropriate?
sciFax said:
"do the rules of QM admit of such an eventuality that two or even more electrons could become attached to a proton/hydrogen nucleus", or "is there a solution to the schrödinger equation for the hydrogen atom which allows for the existence of, say, a hydrogen anion".
I believe the answer to your first question is "yes" and the second is "no".
the second is "no"
Would that be a "no exact solution" no, or a "not even a perturbative numerical solution" no?
If the two electrons are on the opposite sides of the proton at a given time, is the electron-electron repulsive force greater than, or less than the electron-proton attractive force? The electron-proton pair is at a distance r from each other, while the electron-electron pair are at a distance 2r from each other. Considering the Coulomb force drops as 1/r2, you can easily answer that question.
This is analogous to a triplet state where the two electrons have symmetric spins with respect to each other, but antisymmetric spatial components, meaning they are as far away from each other as possible (thus, opposite side from one another).
Zz.
Likes etotheipi
You're splitting hairs - hairs that can't be split at B level. If I told you the third electron doesn't form a bound state but the (e-,H-)scattering amplitude shows a pole, would that help you?
Likes PAllen
As you can probably guess, not very much. Nonetheless, I glanced through this and found it to be ... interesting. Probably a million miles away from what you were talking about.
Without even making any attempt to justify or give any quantum mechanics accounting, hydrides do exist and some are used as reagents; for example, Sodium Borohydride.
note: My understanding on this could be faulty. The hydrogen is present in such compound with a negative charge but the anion is the borohydride anion.
I don't think that's a B level paper. I don't think there may even be a B level answer beyond what has been said.
Likes etotheipi
The electron affinity of helium is estimated at -0.5 eV, meaning it’s energetically unfavorable by that amount to bind an electron to helium. And the situation will probably be worse for H-, since you’re trying to bind two negatively charged objects.
Likes sciFax
And there's a shoe-in for those unfamiliar with (or have forgotten, since it's so long ago!) QM - a simple phrase like "energetically unfavorable" says more than "the (e-,H-) scattering amplitude shows a pole" would, any day. A B-level question needs a B-level answer.
So, one can play with the idea of energetic unfavorability, go back and read the Wiki articles with that in the back of one's mind and maybe - possibly - move a little forwards in trying to understand/encompass the idea of hydrogen anions.
It's a difficult discussion to decide if something is impossible or "possible but just doesn't happen". Probably impossible.
If you like the energetic argument, you probably will like the charge argument. It's easy to bind an electron to a positively charged proton. It's harder but still possible to bind an electron to a neutral hydrogen atom. It's harder still (and doesn't happen) to bind an electron to a negatively charged H- ion. So far as I know there are no stable isolated 2- ions, but if there were, it would be harder still to stick yet another electron on one.
Look at it from this aspect: on classical side, a dielectric object will acquire induced dipole in field of a charge, that will attract the charge.
But from this classical approach, a hydrogen atom as polarizable dielectric should have equal attraction to a proton and an electron.
Hi,
a relatively accessible summary of the understanding of the hydride ion was given by Hylleraas and can be found here:
http://adsabs.harvard.edu/full/1964ApNr...9..345H
He also gives a quite simple approximate wavefunction which yields a very good approximation.
Likes sciFax
DrDu said:
Hi,
Thank you for this - it gives a nice historical perspective on the question of whether the ##H^-## anion could exist.
Also interesting to note that some physics "big names" like Bethe and Chandrasekhar had also turned their attention to the anion.
Related to Hydrogen anions - how do they form?
1. What are hydrogen anions?
Hydrogen anions are negatively charged ions that consist of a single hydrogen atom with an extra electron. They are formed when a hydrogen atom gains an extra electron, giving it a negative charge.
2. How do hydrogen anions form?
Hydrogen anions can form through a process called electron capture, where a neutral hydrogen atom captures an electron from another atom. They can also form through the dissociation of hydrogen molecules in the presence of an electron source.
3. What is the charge of hydrogen anions?
Hydrogen anions have a charge of -1, as they have one more electron than the neutral hydrogen atom.
4. What are the properties of hydrogen anions?
Hydrogen anions are highly reactive and unstable due to their negative charge. They are also smaller in size compared to neutral hydrogen atoms, making them more polarizable.
5. How are hydrogen anions used in science and technology?
Hydrogen anions are used in a variety of scientific and technological applications, such as in plasma physics and nuclear fusion research. They are also used in the production of hydrogen gas and as a reducing agent in chemical reactions.
  • Astronomy and Astrophysics
  • Atomic and Condensed Matter
  • Chemistry
