Hydrogen dew point in power generators
Hydrogen is used as a cooling agent in large power generators, operating at temperatures between +45 to +75 °C. Monitoring the hydrogen dew point is crucial because even minimal air contamination can lead to explosive mixtures. Atmospheric humidity can leak into hydrogen systems, making dew point measurements essential for assessing contamination levels. While total moisture is a concern, dew point is easier to measure and provides valuable insights into system safety. Accurate monitoring helps ensure the safe operation of hydrogen-cooled generators.
abolfazlghasemi
Large power generators (for example 200 MW) are cooled by H2 in gas form. H2 temperature is +45 to +75 "C. So why hydrogen dew point is important in generator while the lowest hydrogen temperature is 45 "C? And in some Power Stations is monitored online...
Thanks, a lot
Welcome @abolfazlghasemi !
Hydrogen is an excellent cooling agent, but is highly explosive when mixed with air.
For that reason is very important to keep both separate.
Some atmospheric humid air can still slowly leak into the hydrogen occupied volumes.
Since it normally contains some water vapor diluted in it (absolute humidity), monitoring the dew point of the hydrogen can tell how much air contamination has happened and how closer to an explosive mix it has become.
Please, see:
https://greenrenpower.com.au/products-and-services/electrolysers/how-h2-cools-generators/
https://able.co.uk/media/2015/08/re...ment-for-electricity-generator-protection.pdf
:cool:
Likes berkeman and Tom.G
I had always understood the varnish winding to be pretty hydrosopic - the issue is not dew point, but total moisture in the system. Dew point is easier to measure and monitor. BUt similarly - I could see it being easier to maesure Dew point then O2 as well - but it would have less correlation.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
