Hydrogen Spectral Series Question
  • Thread starter Thread starter Bevels
    Hydrogen Series
Bevels
I do not understand the distinction between the Lyman, Balmer, Pascher series etc. I understand that you calculate the values in each series with the corresponding n' values but I don't understand the need for multiple series. Why can't you have one overarching series that covers the entire spectrum and why would you use one series instead of another? Also, how to the series compare to each other?
Simple answer: There isn't a need!
They're just named that way because they were discovered experimentally before we knew how it all fits together. It's historic.
Well, the different series represent different electronic transitions. But there is an important equation, the http://en.wikipedia.org/wiki/Rydberg_formula" which describes all of them.. I think you've learned of it since you mention the n values. This lead to the Bohr model of the hydrogen atom, which explained _why_ you had these levels.
Or, almost. See, it turned out that those lines were not actually single lines, but several lines very close together.. And so they had to add more variables to describe how these levels-within-levels fit together.. and the answer to that eventually came from quantum mechanics.
(Edit: Ooh - My 900th post!)
Heres what I am having trouble with. My understanding is that these spectral series correspond to energy levels of the hydrogen atom and that these levels are therefore necessarily quantized. However, as one series overlaps another series, the spectral lines of the previous series becomes quazi continuous at lower frequencies. I don't understand how this quazi-continuous nature of one series can be logically compatable with discrete components of another series which it overlaps. I suppose what I am asking is what is the physical significance of n' in the Rydberg formula and the physical significance of the corresponding series. Here is the plot that I am having problems with: http://en.wikipedia.org/wiki/File:Hydrogen_spectrum.svg
One series may be quazi-continuous at a frenquency where another series is decidedly discrete. How are these things reconcilable?
Each spectral line corresponds to a transition between two atomic energy levels. The photon energy equals the difference in energy between the two levels. In the formula that you're looking at, n is the quantum number of the initial energy level (before the transition), and n' is the quantum number of the final energy level (after the transition).
n' = 1 gives you the Lyman series, n' = 2 gives you the Balmer series, etc.
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
