I am lost, how do I find tension of a rope given A and M?
To find the tension in the rope while lowering a 1.1 kg bucket with an acceleration of 1.9 m/s², apply Newton's second law, where T (tension) and mg (weight) are considered. The correct equation is T - mg = -ma, where g is the acceleration due to gravity (-9.8 m/s²). The net force is the difference between tension and weight, not zero, as the bucket is accelerating downwards. By substituting the values, the tension can be calculated as T = m(g + a), leading to T = 1.1 kg * (9.8 m/s² + 1.9 m/s²) = 12.87 N. Understanding the direction of forces and proper application of the equation is crucial for solving the problem accurately.
Dante
A rope is used to lower a 1.1 kg bucket into a well at an acceleration of 1.9 m/s2. Determine the tension in the rope (in Newtons). Assume that air resistance is negligible and the acceleration due to gravity is -9.8 m/s2. Take the positive direction to be upward.
Newtons 2nd law, A=Fnet/Mnet
T= m (g-a)
-1.9 m/s2 = X/1.1 = -2.09N (wrong)
1.1 (-9.8-1.9) = -12.9N (Unsure if right/wrong)
I am lost, I am suppose to use Newtons 2nd law equation but it makes no sense, please help.
Have you drawn a free body diagram? If T is pointing upward and g is pointing downward, what is the net external force on the bucket?
I did draw a free body diagram, hopefully correctly. The weight would be pulling it down making the tension to pull up causing the net external force to be 0 since they cancel each other out, right? If I plugged 0 into the equation for the net force then what would I solve for, since there would be no X?
Okay, so the tension and weight do not equal each other, instead they add up to equal the net force, correct? Meaning if I use that equation to find the net force, I then add the weight to it to find the tension? Meaning it would be -2.09 + 1.1kg = .99N?
Let T be the upward tension, and mg be the downward force of gravity on the bucket (i.e., its weight). The net of these in the upward direction is T-mg. If a is the upward acceleration, what is Newton's second law written in terms of these parameters? In this problem, is "a" positive (upward) or negative (downward)? What does the force balance you wrote down give you for the tension in the rope?
Chet
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
