I am not a teacher or even student of physics but I am translating a
The discussion centers on translating a physics paper and the appropriate terminology to use regarding "m-dependency." Participants suggest that "dependence on m" is clearer and more conventional than "m-dependency," which requires definition if introduced as a new term. The original sentence is recommended to be split for clarity. The consensus is to use "dependence on m" for accuracy and understanding. Clear communication in scientific translation is emphasized.
Turrialba
I am not a teacher or even student of physics but I am translating a physics paper into English and I need some help. I have a sentence that may translate as follows:
"Newton introduced m-dependency upon taking into consideration, within the context of his second law, the experimental fact that all objects close to the Earth’s surface fall with the same gravitational acceleration."
Does the term "m-dependency" make sense in this context? The literal translation would be "dependence with m" and in previous sentences there is a definition of m as the mass of a planet.
Should I use "m-dependency" or "dependence on/with m"?
Thank you in advance for your patience and understanding.
What does m-dependency mean? Dependence on some mass m?
I would try to split that sentence into two smaller ones.
@mfb, the OP said the paper defined m as the mass of the planet.
I would translate it as "dependence on m". If you want to use a new techincal term like "m-dependency", you need to define what it means.
Thank you. I will use dependence on m.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
