I am trying to run the avira and malware bytes in safe mode
  • Thread starter Thread starter gtguhoij
    bytes Mode
The first method for accessing Safe Mode by holding the Shift key and clicking Restart does not function as intended, leading to a "system image recovery" message instead of "Start-up settings." The second method, using msconfig to enable Safe Mode, is effective but lacks internet access, which is a standard limitation of Safe Mode as it does not load network services. To properly enter Safe Mode, the F4 key can be used during startup. For malware concerns, using bootable antivirus disks or portable versions of scanning software is recommended to perform offline scans without interference from existing malware.
gtguhoij
TL;DR Summary
I am trying to run the avira and malware bytes in safe mode but it doesn't work.
The first method doesn't work. The second method does work but I can't run avira and malware bytes. Can someone help? First method
I hold the shift button and click the restart button.
I click on troubleshoot then click on advance objects then I click on see more recovery options.
The problem is instead of saying Start-up settings it says system image recovery.
What do I do to fix this?
Second method
Windows - Accessing Safe Mode using msconfig
Click the Start button.
Type msconfig and press enter.
In the Boot tab, click the checkbox next to Safe Mode.
If you need to use the internet while in Safe Mode, click Network.
Click Okay.
Your computer will now boot in Safe Mode each time its turned on.
This works but the internet doe not work.
Computer science news on Phys.org
No, this is by design. Safe mode does not start up any services, and Internet access is a service.
Again, that is by design, To start in safe mode, you press the F4 function key repeatedly after restart (at least I think it is F4, I haven't done it for at least 5 years). This brings up a menu where safe mode boot is an option.
I'm assuming you think you may have malware. The big AV providers provide "bootable" disks you can use which will run everything offline so anything on the computer can't interfere with it. Alternatively if you can find a portable version of Windows you can also run "portable / doesn't require install" version of scanners so you can again scan offline as such.
Likes jim mcnamara
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
