I built a 3 stage PWM solar charger using an arduino
An electrical engineering student has developed a three-stage PWM solar charger using an Arduino, primarily for personal enjoyment rather than as a school project. Feedback from the community highlights the importance of documenting the project for future job prospects and suggests adding web-accessible data logging for monitoring battery performance. The charger is designed for lead-acid batteries, which are favored for their cost-effectiveness and durability, although concerns about potential issues with prolonged float charging are noted. The student plans to use the charger for powering lights at night, mitigating float concerns with potential code adjustments. The discussion emphasizes the need for careful consideration when charging different battery types, particularly lithium, due to the lack of current sensing in the current design.
Jamesr
I am an electrical engineering student. I have been on summer break for a few weeks now and I had time to work on my project. This is not a school project but something I had wanted to complete for a while. I haven’t decided what I am going to do with it yet. I just built it for the fun of it. Please tell me what you guys think and ask questions. The link --> http://jr.120v.ac/pwm_charger_project/pwm_charger.php
Hello James - Looks very good! -- Keep this documented well, as employers look for what you can DO as much as what you know! -- I would add web accessible data log, let the arduino report energy converted, battery condition etc - so you can show it off !
Likes Jamesr
Looks pretty cool. I'm assuming Rsc is effectively your current limit.
I'll assume you always stay below the gassing voltage, and that lead Acid batteries do OK with the current pulses during topping and float.
If you float for too long you may have issues. (but maybe it is being used a lot so that is not an issue)
From meBigGuy's comment
... and that lead Acid batteries do OK...
are you interested in charging other battery types? There's a lot more to batteries than most would think. Battery University has excellent information that may interest you.
Nice.
I have read a lot of different experiments that were performed on lead acid batteries. UPS sealed lead acid batteries for alarm systems are kept at a constant float voltage for most of their lifespan and they can last for up to 8-10years without damage. The float voltage is precisely controlled according to the temperature to prevent any form of gassing. I have also read that the small pulses to keep the battery at float is good for the battery because it provides desulphation.
This charger was designed to have lighting run off the battery at night so floating will hopefully not be an issue. If I find that it is an issue, a quick change to the code will fix it.
I chose lead acid just because they are the cheapest and most tolerant of abuse. Most off grid solar systems use lead acid batteries for energy storage. I would probably have to redesign a new charger to work with other battery types. The charger shown in this thread does not have any way to sense current. I would be uncomfortable trying to charge other batteries such as lithium type without current sensing.
Likes dlgoff
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
