I deriving equtions for projectile motion.
The discussion focuses on deriving the equation for the range R of a projectile in terms of its maximum height h, specifically showing that R=4h cot(Θ) and that when the range is maximized, h equals R/4. The user initially attempted to derive R using incorrect equations and later realized the need for the correct height equation. They expressed confusion about how to mathematically demonstrate the relationship between height and range and sought assistance in deriving the necessary equations. Ultimately, the user acknowledged a mistake in their approach and requested further guidance on deriving the correct relationships. The conversation highlights the challenges of understanding projectile motion equations and the importance of using the right formulas.
BarneyStinson
Show that the range R can be expressed in terms of maximum height h, and in particular that R=4hcot\Theta. Show that, when range is at a maximum, h=R/4
R=(v(o)^2*2sin\Thetacos\Theta)/g
v(y)^2=v(yo)^2-2gh
I used the second equation to find a value for v(o)^2 to substitute into the first equation. I got:
v(o)^2=2gh/sin\Theta
Plugged that into the first one:
R=(2gh*2sin\Thetacos\Theta)/sin\Thetag
Simplified to:
R=4hcos\Theta
I don't know how to make it cot\Theta instead of cos. Maybe i used the wrong equations or something.
For (b), I drew the flight path, dividing the range into 4 equal parts, then showed that the height is equal to one of the quarters of the range. I need to show it mathematically, any hints on that?
Thank you guys for any help.
Since my teacher never gave us the equation for height i posted above, he said we have to derive it ourselves... I have no idea how to do this, can you guys help me out?
And i still don't understand how to derive the equation R=h/4
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
