I do not recognize:$$B=\frac{\mu_0 I R^2}{2 R}$$Where did you find it?
  • MHB
  • Thread starter nerdsamurai22
In summary, the conversation is about confusion in dealing with uniform displacement and how to properly use given radii to determine the magnitude. The formula for magnetic field is discussed, specifically one for a straight wire and one for a wire loop. The speaker is seeking advice on how to approach the problem and what context clues to look for.
nerdsamurai22
When dealing with uniform displacement:
I get confused as too know exactly how find and properly utilize the given radii.
Determine the magnitude
i.e.:
given:
R=3.00cm
id=.500A
r=radial distances of displacement 2.00cm, 500cm
b=(mu id)/2pi r
b=(mu id) R^2/2pi r
there are two different variations of the formula^ that correlate with the given parameters. How do I approach this problem? What context clues do I need to look for?
Mathematics news on Phys.org
i.e.:
given:
R=3.00cm
id=.500A
b=(mu id)/2pi r
b=(mu id) R^2/2pi r
Hi nerdsamurai22! Welcome to MHB! :)
Can you clarify what your symbols represent?
Do you perhaps have a drawing?Anyway, the formula:
$$B=\frac{\mu_0 I}{2\pi r}$$
belongs to a straight wire with current $I$. It gives the magnetic field $B$ at distance $r$ from the wire.I do not recognize:
$$B=\frac{\mu_0 I R^2}{2\pi r}$$
Where did you find it?Furthermore, the formula:
$$B=\frac{\mu_0 I}{2 R}$$
gives the magnetic field strength in the center of a wire loop with radius $R$ carrying current $I$.
FAQ: I do not recognize:$$B=\frac{\mu_0 I R^2}{2 R}$$Where did you find it?
What is the process for determining the exact radii of an object?
The process for determining the exact radii of an object involves using mathematical equations, measurements, and data analysis. First, the object's dimensions and shape must be accurately measured. Then, these measurements are plugged into equations to calculate the radii of different sections of the object. Finally, the calculated radii are compared and averaged to determine the exact radii of the object.
How accurate are the methods used to determine exact radii?
The accuracy of determining exact radii depends on the precision of the measurements and the accuracy of the equations used. With precise measurements and accurate equations, the results can be very accurate. However, there may be some margin of error due to factors such as human error or limitations in the measuring equipment.
What types of objects can be measured for their exact radii?
Any object with a defined shape can be measured for its exact radii. This includes simple geometric shapes, such as circles and spheres, as well as more complex shapes like cylinders, cones, and ellipsoids. Even irregularly shaped objects can have their exact radii determined using specialized techniques.
Can the exact radii of an object change over time?
In most cases, the exact radii of an object will remain constant. However, some objects may experience changes in their radii due to factors such as wear and tear or deformation. These changes can be measured and tracked over time to monitor the object's condition.
What are some applications of determining exact radii?
Determining exact radii is essential in many fields, including engineering, manufacturing, and physics. It is used to design and create precise parts and structures, as well as to understand the properties and behavior of objects. It also has applications in fields such as astronomy, where the exact radii of planets and other celestial bodies are crucial for understanding their composition and movements.
