I have a cumbersome problem with Vector calculus
The discussion revolves around the challenges faced by a physics student in understanding vector calculus, particularly when applying the BAC-CAB rule and using the nabla operator. The student expresses difficulty with the concepts and prefers the Ricci-index formalism for calculations. Another participant suggests that learning index notation and the Levi-Civita symbol can simplify the process. They emphasize the importance of showing actual work to identify specific areas of confusion rather than discussing problems in general terms. The conversation highlights the necessity of mathematical techniques in physics education and encourages deeper engagement with the material.
fdbjruitoirew
I am unfamiliar with Vector calculus, a tool for learning Physics
I select a homework I did not solve yet, then hope a help from you guys, in attachment pdf file
My attempt: I tried to use BAC-CAB rule, but the key hardness of mine is I still do not know the concepts clearly (as you know a physics-majored student could not have a lot of time to study Math)
Thank you in advance
I always found the calculus using the nabla symbol a bit cumbersome and "unsafe". For such calculations I prefer the Ricci-index formalism. For the curl of a vector field you write in components
(\vec{\nabla} \times \vec{V})_j=\epsilon_{jkl} \partial_k V_l,
where \epsilon_{ijk} is the fully antisymmetric 3rd-rank tensor with \epsilon_{123}=1, also known as the Levi-Civita symbol.
In the index calculus the bac-cab rule is reflected in the following identity for the Levi-Civita symbol,
\epsilon_{ijk} \epsilon_{ilm}=\delta_{jl} \delta_{km} - \delta_{jm} \delta_{kl},
where we used the Einstein summation convention, i.e., one always has to sum over repeated indices. Further
\delta_{ij}=\begin{cases}<br /> 1 &amp; \text{if} \quad i=j,\\0&amp; \text{if} \quad i \neq j.<br /> \end{cases}<br />
I don't know, what's to "calculate" much with your first expression, but in index calculus it's simply
[(\vec{a} \cdot \vec{\nabla}) \vec{b}]_j=a_i \partial_i b_j.
Here, \partial_i=\frac{\partial}{\partial x_i}.
The second term on your problem list is
[(\vec{a} \times \vec{\nabla}) \times \vec{b}]_j=\epsilon_{klm} a_l \partial_m \epsilon_{jkn} b_n=-\epsilon_{klm} \epsilon_{kjn} a_l \partial_m b_n = -(\delta_{lj} \delta_{mn} - \delta_{ln} \delta_{mj}) a_l \partial_m b_n.
Now you only have to evaluate this a bit further and translate back into the nabla-operator notation.
Likes 1 person
Thanks
I still prefer a direct method than using quite complicated calculation, then find out a meaning behind an expression. Maybe later I would do it smoothly but now I am just newbie with Vector calculus.
What do you mean a physics major doesn't have a lot of time to study math? Mathematical techniques are a big part of what you're supposed to be learning!
vanhees71's suggestion is actually the most straightforward and least complicated way to do those calculations. It's definitely worth spending a little effort to learn how to use index notation and the Levi-Civita symbol.
Nevertheless, you can definitely do the problem by writing it all out, component by component. Show us what you've done. Don't just describe what you did in general terms. That's pretty useless. Show us your actual work so we can see where you're getting stuck.
Hi. I'll be curious. I've started a course on continuum mechanics, and we are using this notation for tensor calculus. Can you give a demonstration for these formulas you've posted? or tell me where to find'em?
Thanks.
The formula is pretty easy to justify. Take the first term in the sum, i.e.,
\epsilon_{1jk} \epsilon_{1lm}.
Obviously this can only be different from 0 if j,k \in \{2,3\} and at the same time l,m \in \{2,3 \}. Thus you either have
j=l \quad \text{and} \quad k=m
or
j=m \quad \text{and} \quad k=l.
In the first case the two epsilon symbols are both +1 or both -1, and their product thus always 1. This gives you
In the other case you get
-\delta_{jm} \delta_{kl}.
This same argument works of course for the other two values of the summation index i=2 and i=3, and this proves the formulat.
Likes 1 person
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
