Undergrad I have a question about gravity -- If the value of the energy momentum tensor (Tμν) becomes zero, can it become gravitational-free?
If the energy momentum tensor (Tμν) is zero everywhere, it indicates a gravitational-free state, akin to a vacuum solution in general relativity. However, this does not imply the presence of anti-gravity; it simply represents empty space without mass or energy. The discussion draws parallels to electromagnetism, where a field exists due to a charge, but in the absence of energy momentum, no gravitational effects are present. The Schwarzschild black hole geometry exemplifies this, as it describes a vacuum solution with no stress-energy but still possesses a singularity. Ultimately, a zero Tμν signifies a lack of gravitational influence rather than an anti-gravitational effect.
seonjunyoo
R μν − 1/2g μν R= 8πG/c^4T μν
In this formula, if the value of the energy momentum tensor(Tμν) becomes zero, can it become gravitational-free?
Only if it's zero everywhere. Think of electromagnetism. This is an EM field everywhere caused by a single charge.
PS also, in the Schwartzschild black hole geometry, there is no stress-energy. It's a vacuum solution. There is however a characteristic mass and a singularity.
Then, if the energy momentum tensor everywhere is zero, is it possible to assume that it is anti-gravity?
No, that's just empty space.
Likes Vanadium 50 and PeroK
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 28 ·
  • · Replies 16 ·
  • · Replies 38 ·
