MHB I have the data and need to make a prediction based on it (probability)
To predict the number of births in 2010 using the provided linear regression equation, the independent variable x should be set to 2010. By substituting x into the equation y = -0.1103x + 234.98, the predicted birth rate for that year is calculated to be approximately 13.277. The discussion clarifies the confusion around the variable representation, confirming that x indeed represents the years. Participants agree on the calculation and the resulting prediction. This straightforward approach to using linear regression helps in making data-driven predictions.
chriskeller1
Hello Everyone,
I really can't understand stats and it's driving me crazy.
I have data for births linked with different years, the graphic looks like this
But I need to make a prediction on the births in year 2010. How do I go about that?!
Mathematics news on Phys.org
It looks like you are provided with the linear regression:
$$y=-0.1103x+234.98$$
Can you see what you need to use for $x$ to get a prediction for the year 2010?
I'm confused... Isn't x supposed to represent the years?
Yes, it appears to me that the independent variable $x$ is the year, and this input into the given line will give a prediction for the output, the dependent variable which is the birth rate, for that year.
So, use $x=2010$ in the given line, and what do you find?
Oh, so basically it's going to be 13.277?
Thank you!
Thank you!
Yes, that's the same value I get. (Yes)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
