MHB I made 2 equations but can they become 1
  • Thread starter Thread starter DRMSquared
The discussion revolves around combining two equations to simplify a CNC machine operation. The first equation, which uses arcsine, calculates an angle based on the chord and radius, while the second equation uses that angle to compute the necessary input for the machine. By substituting the first equation into the second, a single equation is formed: y = r*sin(0.5*arcsin(C/r)). This simplification allows for easier calculations on a calculator. The user expresses gratitude for the assistance in streamlining the process.
DRMSquared
So a little background then to the point, I needed to get a cnc machine to do something it don’t want to do, so I came up with 2 equations to lie to the machine to get it to do an operation correctly. It is a radius equation that finds the center point of a radius if it is not a full radius. Can these be combined to make one?
1st: Asin(chord/radius)=x
2nd: radius[sin(x/2)]=y
Y is the input for the machine, it’s the important answer.
Mathematics news on Phys.org
Welcome, DRMSquared! (Wave)
In the first equation, does Asin mean the Arcsine, or does it mean $A$ times sin where $A$ is some constant?
It would be sin-1 so I’m guessing arcsine
Ok. For simplicity, let $C = \text{chord}$ and $r = \text{radius}$. Equation 1 is then $x = \arcsin(C/r)$. Plugging in the expression of $x$ into Equation 2 yields $$y = r\sin(.5\arcsin(C/r))$$
You my friend are awesome, thank you so much, now I can easily plug this into my hp48g and have an easier and quicker time doing this problem.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
